f the 6th digit from the right is "R", return Right(5), if not return right(3)
bluepenguin3
I have a column of sample names that are a mixture of letter, numbers, and hyphens. I want to create another column that will produce a shortened version of that name.
Here is the basic premise of what I want from excel:
If the 6th digit from the right is "R", return Right(5), if not, return right(3).
Here are the results I want from this formula:
Sample Name                          Vial Name
11-2345 RG-3Z4                        RG-3Z4
30456-154-YRF RG-PP1                    RG-PP1
131-2345-ZJQ                            ZJQ
122-2345 RG-3Z4CT4VF5Q01               Q01
I've got the IF formula working fine, but I can't figure out how to make the first bit of the formula work, because I need to work from the right of the string, rather than from the left. Mid doesn't work, because I'm moving from the right, and there isn't a consistent # of characters working from the left.
The sample names are all different lengths and "R" can appear throughout the name, but I only care if "R" is the 6th digit from the right. So, that makes me think that search or find won't work either.
What do you think? Thanks!
Hi!
This could be an option:
=RIGHT(A2,3+3*(MID(A2,LEN(A2)-5,1)="R"))
Or:
=RIGHT(A2,3+3*COUNTIF(A2,"*R?????"))
Blessings!
