Jitender Singh Tomar
Hello All,
I am struggling with a Excel VBA Code for making Chart.
I'm working on below code and wanted to add few more line to this chart.
I will brief about my requirement...I have two columns with Values on which chart is to be build and based on the number of values chart should give Average, Minimum Value, Maximum Value and UCL (Upper Control limit) and Lower Control Limit (LCL).
this below code gives me Avg and LCL, UCL but not min and max and also UCL, LCL is required for level 3 only not for each level.
if anybody could help me to modify this code please.
Thanks a ton.
Moved to VBA Macros
Thanks a ton.
Sub make_control_chart()
Dim data_values As Range
Dim chart_labels As Range
Dim range_selected_before As Range
Dim got_label_range As Boolean
Dim got_value_range As Boolean
Dim bActivate As Boolean
Dim myChtObj As ChartObject
Dim plot_series, MyNewSrs As Series
Dim series_label As String
Dim number_of_control_limits As Integer
Dim standard_deviation As Integer
Dim data_str As String
Dim avg_str As String
On Error GoTo if_error_occured:
'GET RANGE FOR DATA VALUES
bActivate = False ' True to re-activate the input range
Set data_values = GetRange("Please select the range containing the DATA POINTS" & Chr(13) & "(press select a single column)")
If IsNotOk(data_values) Then
MsgBox "Incorrect Input Data !"
End
ElseIf Not (check_if_numeric(data_values)) Then
End
'GET RANGE FOR CHART X-AXIS LABELS
got_label_range = True ' True to re-activate the input range
Set chart_labels = GetRange("Please select the range containing the LABELS" & Chr(13) & "(press ESC if no labels available)")
If IsNotOk(chart_labels) Then
got_label_range = False
'LETS CREATE THE CHART NOW
Set myChtObj = ActiveSheet.ChartObjects.Add(Left:=100, Width:=400, Top:=25, Height:=300)
myChtObj.Chart.ChartType = xlLineMarkers
'REMOVE ALL UNWANTED SERIES FROM CHART, IF ANY
For Each MyNewSrs In myChtObj.Chart.SeriesCollection ' myChtObj.Chart.SeriesCollection
MyNewSrs.Delete
Next MyNewSrs
Set MyNewSrs = Nothing
If got_label_range Then 'IF WE HAVE THE LABEL RANGE
'ADD NEW SERIES
Set MyNewSrs = myChtObj.Chart.SeriesCollection.NewSeries
With MyNewSrs
.Name = "PLOT"
.Values = data_values
.XValues = chart_labels
With MyNewSrs
.Name = "PLOT"
'FORMAT THE PLOT SERIES
Set plot_series = MyNewSrs
With MyNewSrs
.Border.ColorIndex = 1
.MarkerBackgroundColorIndex = 2
.MarkerForegroundColorIndex = xlAutomatic
.MarkerStyle = xlCircle
.Smooth = False
.MarkerSize = 5
.Shadow = False
'CREATE NAMED RANGE FOR THE DATA VALUES, AVERAGE, LOWER AND UPPER CONTROL LIMITS
data_str = Application.WorksheetFunction.Substitute(myChtObj.Name, " ", "") & "_data_values"
avg_str = "roundup(average(" & Application.WorksheetFunction.Substitute(myChtObj.Name, " ", "") & "_data_values" & "),2)"
ActiveWorkbook.Names.Add Name:=Application.WorksheetFunction.Substitute(myChtObj.Name, " ", "") & "_data_values", RefersToR1C1:=data_values
ActiveWorkbook.Names.Add Name:=Application.WorksheetFunction.Substitute(myChtObj.Name, " ", "") & "_AVG", RefersToR1C1:="=" & avg_str & ""
ActiveWorkbook.Names.Add Name:=Application.WorksheetFunction.Substitute(myChtObj.Name, " ", "") & "_LCL1", RefersToR1C1:="=" & avg_str & "- roundup(1*stdev(" & data_str & "),2)"
ActiveWorkbook.Names.Add Name:=Application.WorksheetFunction.Substitute(myChtObj.Name, " ", "") & "_LCL2", RefersToR1C1:="=" & avg_str & "- roundup(2*stdev(" & data_str & "),2)"
ActiveWorkbook.Names.Add Name:=Application.WorksheetFunction.Substitute(myChtObj.Name, " ", "") & "_LCL3", RefersToR1C1:="=" & avg_str & "- roundup(3*stdev(" & data_str & "),2)"
ActiveWorkbook.Names.Add Name:=Application.WorksheetFunction.Substitute(myChtObj.Name, " ", "") & "_UCL1", RefersToR1C1:="=" & avg_str & "+ roundup(1*stdev(" & data_str & "),2)"
ActiveWorkbook.Names.Add Name:=Application.WorksheetFunction.Substitute(myChtObj.Name, " ", "") & "_UCL2", RefersToR1C1:="=" & avg_str & "+ roundup(2*stdev(" & data_str & "),2)"
ActiveWorkbook.Names.Add Name:=Application.WorksheetFunction.Substitute(myChtObj.Name, " ", "") & "_UCL3", RefersToR1C1:="=" & avg_str & "+ roundup(3*stdev(" & data_str & "),2)"
'ADD THE LINE FOR AVERAGE
With MyNewSrs
.Name = "AVG = "
.Values = "='" & ActiveSheet.Name & "'!" & Application.WorksheetFunction.Substitute(myChtObj.Name, " ", "") & "_AVG"
.ChartType = xlXYScatter
'.ErrorBar Direction:=xlX, Include:=xlNone, Type:=xlFixedValue, Amount:=10000
'.ErrorBar Direction:=xlX, Include:=xlUp, Type:=xlFixedValue, Amount:=20
.ErrorBar Direction:=xlX, Include:=xlPlusValues, Type:=xlFixedValue, Amount:=data_values.Rows.Count
.MarkerBackgroundColorIndex = xlAutomatic
.MarkerStyle = xlNone
.Smooth = False
.MarkerSize = 5
.Shadow = False
With .Border
.Weight = xlHairline
.LineStyle = xlNone
'With .ErrorBars.Border
' .LineStyle = xlContinuous
' .ColorIndex = 3
' .Weight = xlThin
'End With
'ADD UPPER AND LOWER CONTROL LIMITS
For number_of_control_limits = 1 To 3
For standard_deviation = -1 To 1 Step 2
Select Case standard_deviation:
Case -1: series_label = "LCL"
Case 1: series_label = "UCL"
End Select
With MyNewSrs
.Name = series_label & number_of_control_limits & " ="
.Values = "='" & ActiveSheet.Name & "'!" & Application.WorksheetFunction.Substitute(myChtObj.Name, " ", "") & "_" & series_label & number_of_control_limits
MyNewSrs.ErrorBar Direction:=xlX, Include:=xlPlusValues, Type:=xlFixedValue, Amount:=data_values.Rows.Count
Select Case number_of_control_limits:
Case 1:
With MyNewSrs.ErrorBars.Border
.LineStyle = xlGray25
.ColorIndex = 15
Case 2:
.ColorIndex = 57
Case 3:
.LineStyle = xlGray75
.ColorIndex = 3
End Select
MyNewSrs.ErrorBars.EndStyle = xlNoCap
With MyNewSrs
With .Border
.LineStyle = xlNone
.Smooth = False
.MarkerSize = 5
.Shadow = False
Next standard_deviation
Next number_of_control_limits
myChtObj.Chart.ApplyDataLabels AutoText:=True, LegendKey:=False, _
HasLeaderLines:=False, ShowSeriesName:=True, ShowCategoryName:=False, _
ShowValue:=True, ShowPercentage:=False, ShowBubbleSize:=False, Separator:=" "
'OFFSET THE LABELS
With MyNewSrs.Points(1).DataLabel
.Left = 400
Next MyNewSrs
'LETS FORMAT THE CHART
With myChtObj
With .Chart.Axes(xlCategory)
.MajorTickMark = xlNone
.MinorTickMark = xlNone
.TickLabelPosition = xlNextToAxis
With .Chart.Axes(xlValue)
.MajorTickMark = xlOutside
With .Chart.ChartArea.Border
.Weight = 1
.LineStyle = 0
With .Chart.PlotArea.Border
.ColorIndex = 1
.Weight = xlThin
With .Chart.PlotArea.Interior
.ColorIndex = 2
.PatternColorIndex = 1
.Pattern = xlSolid
With .Chart.ChartArea.Font
.Name = "Arial"
.Size = 8
.Strikethrough = False
.Superscript = False
.Subscript = False
.OutlineFont = False
.Shadow = False
.Underline = xlUnderlineStyleNone
.ColorIndex = xlAutomatic
.Background = xlAutomatic
With .Chart
.HasTitle = False
.Axes(xlCategory, xlPrimary).HasTitle = False
.Axes(xlValue, xlPrimary).HasTitle = True
.HasTitle = True
.ChartTitle.Characters.Text = "Control Chart"
.ChartTitle.Left = 134
.Axes(xlValue, xlPrimary).AxisTitle.Characters.Text = "Observations"
With .Chart.Axes(xlCategory).TickLabels
.Alignment = xlCenter
.Offset = 100
.ReadingOrder = xlContext
.Orientation = xlHorizontal
myChtObj.Chart.Legend.Delete
myChtObj.Chart.PlotArea.Width = 310
myChtObj.Chart.Axes(xlValue).MajorGridlines.Delete
myChtObj.Chart.Axes(xlValue).CrossesAt = myChtObj.Chart.Axes(xlValue).MinimumScale
myChtObj.Chart.ChartArea.Interior.ColorIndex = xlAutomatic
myChtObj.Chart.ChartArea.AutoScaleFont = True
'DELETE THE LABELS FOR THE ACTUAL DATA SERIES
plot_series.DataLabels.Delete
Set plot_series = Nothing
if_error_occured:
If Err.Number Then z_delete_all_named_range
Moved to VBA Macros
