Does VBA macros have a max number of cells?
Gungnir5
I just used the Macro recorder and created this "Fill_Blanks" code. I have a column w many blanks. I want to fill in all the blanks by referring to the last non-blank cell above. (I tried the GoTo Special Blanks =cellref CTRL+ENTER trick, but the range was too big) I was wondering if I am running into the same problem w my macro. It just takes the last non-blank cell and pastes it all the way down :(
If so how can I automate the range selection to make this macro work? where should I put the offset line?
hxxps://www.box.com/s/9q5zux47cz9oljaercrf
Here's the xlsm file. I just had to reinstall everything on my system bc I screwed something up in my registry so I promise it's malware/virus free!
All help appreciated!!
Sub Fill_Blanks()
Range(Selection, ActiveCell.SpecialCells(xlLastCell)).Select
Selection.SpecialCells(xlCellTypeBlanks).Select
Selection.FormulaR1C1 = "=R[-1]C"
ActiveCell.SpecialCells(xlLastCell).Select
Maybe I was thinking too hard...this works well and doesn't require vba :P
= if(A3="",B2,A3)
Put that into an empty column. Problem solved!!
