Is anybody can tell me difference between module and class module. The reason being when we press ALT+F11, displays a window. and any VB Code/macro to be inserted in module to get desired program executed.
The difference is enormous ; the two are totally different , and the expertise required to code using class modules is much more than that required to code standard modules.
You need to read a lot to really come to grips with classes ; see these links :
Thank you. I will go through it and get enough knowledge.
One more thing, how can I insert a hyperlink when referring to another post just like you have done here.
I think using the full address , inclusive of the http:// , makes the forum software recognize it as a hyperlink ; have you tried it and has it not worked ?
