Data Query based on Button Clicks VBA help required
Status
Not open for further replies.
ajayxlnc2
Duplicate Thread
http://www.ozgrid.com/forum/showthread.php?t=194969&p=747208#post747208
Mod Edit: Answer given on Ozgrid thread, closing this thread
I have a planning dashboard which will provide the various aspects regarding the employee.
There are 3 sheets
Decision support tool
9-Box distribution
Emp Database
In Emp Database WS is where all the Employee Database is stored. B35 to AB35. The same range for Decision support tool WS and 9-Box distribution WS.
In Decision support tool WS I have created buttons for various Teams (Group2, Group3, Group4...)
My Requirement is,
Requirement 1
In Decision support tool WS, when I select the Tower from the drop down F23 and its related team in F24 and click on Run (button), I want to display the content in Columns B to O for the select tower and its related group. (The data should be picked from the table in Emp Database WS).
In Decision support tool, For that selected Tower and for selected Group, when I click on the Buttons (Group2, Group3, Group4, Group5, Group6) based on the employee group the content should be displayed.
For Example I have selected Tower1 in F23 and Tower_1_Team_2 in F24 and when I click on the any of the button (Group2, Group3, Group4, Group5, Group6), I want to display the content for that particular group which I have clicked.
Requirement 2
In Decision support tool, Columns Q to V and X to AB are updated manually by the managers.
Managers will update the information from Column O to Column AB (****Excluding the Column P, W, X --> as these columns contain formulas and they should not chage). Once they have updated the information and click on Update Date button i want the code to paste the values of that particular resource (Tower/Team selected in drop down) Paste Special --> Values From Column O to Column AB in Decision suppor tool WS to Employee Database
Based on the drop down for Tower/Team selected in F4 & F5 the data for that particular tower/group should be copied from Employee Database WS (Column B to Column AB) and paste special values in the table (Column B to Column AB).
Please help me out in this.
Your Help in highly appreciated.
Thanks in Advance.
Sample attached.
Code which I am currently using
Sub Clear_Data()
  Dim ws1          As Worksheet
  Dim LR1          As Long
  Dim LC1          As Long
  Set ws1 = Sheets("Decision support tool")
  With ws1
      LR1 = .Cells.Find("*", .Cells(.Rows.Count, .Columns.Count), SearchOrder:=xlByRows, _
                        SearchDirection:=xlPrevious).Row
      LC1 = .Cells.Find(What:="*", After:=[A1], SearchOrder:=xlByColumns, _
                        SearchDirection:=xlPrevious).Column
      If LR1 = 35 Then LR1 = 36
      .Range(.Cells(36, "B"), .Cells(LR1, LC1)).ClearContents
Sub Run_Me()
  Dim ws          As Worksheet
  Dim rng          As Range
  Dim LR          As Long
  Dim LC          As Long
  Dim LR1          As Long
  Dim LC1          As Long
  Dim x            As Long
  Set ws = Sheets("Emp Database")
  With ws1
  With ws
      LR = .Cells.Find("*", .Cells(.Rows.Count, .Columns.Count), SearchOrder:=xlByRows, _
      LC = .Cells.Find(What:="*", After:=[A1], SearchOrder:=xlByColumns, _
      .Range(.Cells(35, "B"), .Cells(LR, LC)).AutoFilter field:=4, Criteria1:=ws1.Range("F23").Value
      .Range(.Cells(35, "B"), .Cells(LR, LC)).AutoFilter field:=5, Criteria1:=ws1.Range("F24").Value
      Set rng = .AutoFilter.Range
      x = rng.Columns(1).SpecialCells(xlCellTypeVisible).Count - 1
      If x >= 1 Then
        .Range(.Cells(36, "B"), .Cells(LR, LC)).SpecialCells(xlCellTypeVisible).Copy
        ws1.Range("B36").PasteSpecial
        MsgBox "No Records Found"
      .AutoFilterMode = False
Sub DoTheWork()
  Dim myBtn        As Button
  Dim myGroup      As String
  Dim ws          As Worksheet
  Dim LC          As Long
  Dim LR          As Long
  Set myBtn = Sheets("Decision support tool").Buttons(Application.Caller)
  myGroup = Right(myBtn.Caption, 1)
  Set ws = Sheets("Decision support tool")
  With ws
      If Not .AutoFilterMode Then
      .Range(.Cells(35, "B"), .Cells(LR, LC)).AutoFilter field:=8, Criteria1:=myGroup
Sub Show_All()
  Sheets("Decision support tool").ShowAllData
  On Error GoTo 0
Sub Update()
  Dim ws          As Worksheet
  Dim rng          As Range
  Dim rng1        As Range
  Dim cel          As Range
  Dim c            As Range
  Dim LR          As Long
  Dim LR1          As Long
  Dim LC1          As Long
  With ws1
      Set rng1 = ws1.Range(ws1.Cells(36, "B"), ws1.Cells(LR1, "B")).SpecialCells(xlCellTypeVisible)
  With ws
      Set rng = ws.Range(ws.Cells(36, "B"), ws.Cells(LR, "B"))
  For Each cel In rng1
      Set c = rng.Find(cel.Value, , xlValues, xlWhole, xlByRows, xlNext, False)
      ws1.Range(ws1.Cells(cel.Row, "B"), ws1.Cells(cel.Row, LC1)).Copy
      ws.Cells(c.Row, "B").PasteSpecial (xlPasteValues)
  Next cel
  • Sample Planning 2.zip
Status
