Data Extraction from Webpage to Excel using VBA
I was trying to pull a table from Webpage, so far i was successful pull a table from Webpage, unfortunately i have some links in each row of table, when i pulled the table from Webpage, i am getting output without link, just text, is there any way we can pull table from webpage using VBA including hyperlinks.
Here is my code:
Sub TableExample()
Dim IE As Object
Dim doc As Object
Dim strURL As String
strURL = "HERE I USED MY URL"
' replace with URL of your choice
Set IE = CreateObject("InternetExplorer.Application")
With IE
'.Visible = True
.Navigate strURL
Do Until .readyState = 4: DoEvents: Loop
Do While .Busy: DoEvents: Loop
Set doc = IE.Document
GetAllTables doc
.Quit
Sub GetAllTables(doc As Object)
' get all the tables from a webpage document, doc, and put them in a new worksheet
Dim ws As Worksheet
Dim rng As Range
Dim tbl As Object
Dim rw As Object
Dim cl As Object
Dim tabno As Long
Dim nextrow As Long
Dim I As Long
Set ws = Worksheets.Add
For Each tbl In doc.getElementsByTagName("TABLE")
tabno = tabno + 1
nextrow = nextrow + 1
Set rng = ws.Range("B" & nextrow)
rng.Offset(, -1) = "Table " & tabno
For Each rw In tbl.Rows
For Each cl In rw.Cells
rng.Value = cl.outerText
Set rng = rng.Offset(, 1)
I = I + 1
Next cl
Set rng = rng.Offset(1, -I)
I = 0
Next rw
Next tbl
ws.Cells.ClearFormats
Assist me.
Sorry, 'cause of "your" code I thought you were a developer ‼
So you have to study the webpage structure to find out links …​
