Copy paste taking reference of source destination range from input box
Dee
I am trying to copy few columns using input box and paste it in the destination cells/range using inputbox. In the below code i am unable to paste it in the destination cell as i am getting "Run time error '438'","Object doesn't support this property or method".
my codes
Sub DFMA_MAKE()
Dim sourcefile As Workbook
Dim source_file As String
Dim myrange As Range
Dim desti_range As Range
source_file = Application.GetOpenFilename(FileFilter:="Excel files (*.xls), *.xls", Title:="Please choose a file")
Set sourcefile = Workbooks.Open(Filename:=source_file, ReadOnly:=yes)
Set myrange = Application.InputBox _
(Prompt:="Select any range", Title:="Select the range", Type:=8)
myrange.Copy
Workbooks("DFMA Template_P latest.xlsm").Activate
Worksheets("DFMA MAKE").Select
Set desti_range = Application.InputBox _
(Prompt:="Select range", Title:="Select the Destination range", Type:=8)
desti_range.Paste
Range("A2").Select
sourcefile.Close SaveChanges = no
Please direct me to the correct codes.
Thanks in advance,
Dee
Hey Dee,
You are getting that error message as the Copy Mode is getting deactivated when you try selecting the destination range.
You can try using the destination cell as a variable (depends on your requirement)
SS23
Thanks for your quick response.
I tried with defining destination cell as variable but no luck :(
Its giving "compile error", "User-defined type not defined".
Dee...
When you used a variable range/cell, did you still use:
[pre]
desti_range.Paste
Then it no more works, but if you just use
Range("A" & rcount).Select '*see below
activesheet.paste
[/pre]
then it should work.
*rcount or any "x" being a variable can be used- You can also change the column based on your need
S23
