Copy paste range from excel to ppt as a bitmap - VBA help [SOLVED]
sam77
I need to copy paste a range as a bitmap from excel to ppt. I have a code which copies individual graphs into seperate slides as bitmap images, however would need a code to copy a range. Could any one help. Would you need the code that i have.
Sam
Here is the code... that i have.... i got it from Chandoo.org itself... can anyone tweak it to a copy range...
Sub CreatePowerPoint()
'Add a reference to the Microsoft PowerPoint Library by:
'1. Go to Tools in the VBA menu
'2. Click on Reference
'3. Scroll down to Microsoft PowerPoint X.0 Object Library, check the box, and press Okay
'First we declare the variables we will be using
Dim newPowerPoint As PowerPoint.Application
Dim activeSlide As PowerPoint.slide
Dim cht As Excel.ChartObject
'Look for existing instance
Set newPowerPoint = GetObject(, "PowerPoint.Application")
On Error GoTo 0
'Let's create a new PowerPoint
If newPowerPoint Is Nothing Then
Set newPowerPoint = New PowerPoint.Application
'Make a presentation in PowerPoint
If newPowerPoint.Presentations.Count = 0 Then
newPowerPoint.Presentations.Add
'Show the PowerPoint
newPowerPoint.Visible = True
'Loop through each chart in the Excel worksheet and paste them into the PowerPoint
For Each cht In ActiveSheet.ChartObjects
'Add a new slide where we will paste the chart
newPowerPoint.ActivePresentation.Slides.Add newPowerPoint.ActivePresentation.Slides.Count + 1, ppLayoutText
newPowerPoint.ActiveWindow.View.GotoSlide newPowerPoint.ActivePresentation.Slides.Count
Set activeSlide = newPowerPoint.ActivePresentation.Slides(newPowerPoint.ActivePresentation.Slides.Count)
'Copy the chart and paste it into the PowerPoint as a Metafile Picture
cht.Select
ActiveChart.ChartArea.Copy
activeSlide.Shapes.PasteSpecial(DataType:=xlBitmap).Select
'Set the title of the slide the same as the title of the chart
activeSlide.Shapes(1).TextFrame.TextRange.text = cht.Chart.ChartTitle.text
'Adjust the positioning of the Chart on Powerpoint Slide
newPowerPoint.ActiveWindow.selection.ShapeRange.Left = 15
newPowerPoint.ActiveWindow.selection.ShapeRange.Top = 125
activeSlide.Shapes(2).Width = 200
activeSlide.Shapes(2).Left = 505
'If the chart is the "US" consumption chart, then enter the appropriate comments
If InStr(activeSlide.Shapes(1).TextFrame.TextRange.text, "US") Then
activeSlide.Shapes(2).TextFrame.TextRange.text = Range("J7").Value & vbNewLine
activeSlide.Shapes(2).TextFrame.TextRange.InsertAfter (Range("J8").Value & vbNewLine)
'Else if the chart is the "Renewable" consumption chart, then enter the appropriate comments
ElseIf InStr(activeSlide.Shapes(1).TextFrame.TextRange.text, "Renewable") Then
activeSlide.Shapes(2).TextFrame.TextRange.text = Range("J27").Value & vbNewLine
activeSlide.Shapes(2).TextFrame.TextRange.InsertAfter (Range("J28").Value & vbNewLine)
activeSlide.Shapes(2).TextFrame.TextRange.InsertAfter (Range("J29").Value & vbNewLine)
'Now let's change the font size of the callouts box
activeSlide.Shapes(2).TextFrame.TextRange.Font.Size = 16
AppActivate ("Microsoft PowerPoint")
Set activeSlide = Nothing
Set newPowerPoint = Nothing
On Error GoTo 0
cht.Select
On Error GoTo 0
cht.Select
On Error GoTo 0
cht.Select
I can't code it out for you, but maybe I could give you a start.
You could copy the range you want, then paste+special as a picture. Then, select the picture, copy it, then paste in your ppt.
You could record this in the macro recorder, then substitute the necessary pieces into the code you already have for graphs.
Good luck!
Hi Sam ,
Have you tried this ?
[pre]
Public Sub pickup()
Dim XLApp As Excel.Application
Dim PPSlide As Slide
Set XLApp = GetObject(, "Excel.Application")
XLApp.Range("A1").Select
XLApp.Selection.CopyPicture Appearance:=xlScreen, Format:=xlPicture
Set PPSlide = ActivePresentation.Slides.Add(1, ppLayoutObject)
PPSlide.Shapes.Paste
[/pre]
This is in a VB module in your Powerpoint presentation. Your Excel workbook should be open when you run this , otherwise the file's path should be specified in the GetObject function , as the first parameter.
