Copy Filtered Cells with formulas & Paste them back as values without clear filter
AAP
I would like to create an add-in which I can use to do operation like Copy Visible (filtered) Cells with formulas and paste them back without clearing filter. Any suggestion how can I achieve this.
Regards/Amit
Hi !
The VBA Copy method takes only visible cells so no trap,
beginner level : just read VBA help of this method !
Another must see method : PasteSpecial
Also you can activate Macro recorder and you will get your code …
Hi !
Hi Marc,
Thanks for you suggestion, but I can't see that you copy the filtered range that contains formulas and paste over it again as values.
It's clearly stated in VBA help of PasteSpecial method !
Start to do it manually, Copy then PasteSpecial via right click menu …
Activate Macro recorder to obtain a base of code.
See also in VBA help SpecialCells method …
Another way : Range.Formula = Range.Value
Hi Amit ,
See the attached file.
Apply a filter on the formula field which is column P. Run the macro named CopyFilter. The formulae in the filtered range should be replaced by their values.
  • example.xlsm
Hi Amit ,
Awesome, thanks a lot :) You are really genius.
Hi Marc,
I appreciate your initiative for helping but sometimes a little example help newbie's to understand the concept. Thanks a lot!
Regards/Amit
With Sheet1.Range("A1:F9")
    .Formula = .Value
