copy data from all workbooks(in D drive) from column A and paste in required sheet.
Amit Modi
I have 10 workbooks its named as 1.xlsx, 2.xlsx, 3.xlsx to.....10.xlsx. Its location is “D:\Data\ “ in Data folder.
My required data are in column B in each workbook.
i want all data in column A in my target book named “targert.xlsx”.
I want this using one button click please help me for the same.
Please find further details and sample workbook in attached sheet.
Thank u very much.
  • target.xlsx
Hi Amit,
So in target file starting from A1 first all 1.xlsx B column data should populate than 2.xlsx data and so on till 10.xlsx?
Is it so?
Hi Amit
This should hit the mark quite efficiently. Just remember to change the path.
Sub OpenImp() 'Excel VBA to open and import data
    Const sPath = "C:\Test\" 'Change to suit
    Dim sFil As String
    Dim owb As Workbook
    Dim ws As Worksheet
    Set ws = Sheet1
    sFil = Dir(sPath & "*.xl*") 'Flexible enough to handle all XL file types
    Do While sFil <> "" 'Only Copies Cols B
        Set owb = Workbooks.Open(sPath & sFil)
        Range("B1", Range("B" & Rows.Count).End(xlUp)).Copy ws.Range("A" & Rows.Count).End(xlUp)(2)
        owb.Close False'Close No need to save
        sFil = Dir
    Loop
There is no need to save the files as you are only opening them to get the data. It is just a use and abuse type setup.
see also article 2.
Importing Files No Fuss
Take care
Smallman
Hi Smallman, what if i want to copy data from Column A1 to P9784.
How this macro will work?
Maunish Patel
Hi
Remove this line:
And change to this line:
[A1:P9784].copy ws.Range("A"& Rows.Count).End(xlUp)(2)
Take care
Smallman
