Convert formulas into values (not continuous range)
Jovica
I have two columns with cells linked to another workbook, I would like to convert those cells to values. Problem is that they are not connected (after every couple of rows there is a sum function which I would like to stay intact), so I can not use line .Value = ...Value in VBA.
Cells that needs to be converted to values are selected with macro that selects unlocked cells.
Sub SelectUnlockedCells()
    Dim WorkRange As Range
    Dim FoundCells As Range
    Dim Cell As Range
    Set WorkRange = ActiveSheet.UsedRange
    For Each Cell In WorkRange
        If Cell.Locked = False Then
            If FoundCells Is Nothing Then
                Set FoundCells = Cell
                Set FoundCells = Union(FoundCells, Cell)
    Next Cell
        MsgBox "All cells are locked."
        FoundCells.Select
I could write manual macro for every few cells with Value/Value line, but I'm sure that there is an easier way.
