Conditional formatting - Help - Bit complicated
ramnaidu
Hi All
Hope you are doing well.
I have a value in Sheet 1 in cell A1, if the cell value (A1, Sheet 1) is in the Top 25% of the values of column A in sheet 2, I want to get green, between top 25% to 75% to Amber and bottom 25% to Red.
How can I do it, please help.
Hi Ram,
Please check the attached file if this is what you are looking for.
Hi AIM
Thanks for your message, but it was bit different what I need.
In sheet 1 there is only one cell C1(and the data in it comes from no of calculations) and there are 100 cells in sheet 2.
If C1 in sheet 1 is in top 25 of 100 cells in sheet 2 then it should be green.
The value of C1 in sheet 1 will change frequently and so conditional formatting should change accordingly.
Hope I have explained you the situation correctly.
Good day ramnaidu
You do not see CF as such, it is applied to the cells as per the CF rules.
The above are the rules that Somendra has put in place.
=A1<QUARTILE(Sheet2!$A$1:$A$19,1)
=AND(A1>=QUARTILE(Sheet2!$A$1:$A$19,1),A1<=QUARTILE(Sheet2!$A$1:$A$19,3))
=A1>=QUARTILE(Sheet2!$A$1:$A$19,3)
Good day ramnaidu
Hi BOB
Thanks for the reply
Please find the attached spreadsheet and help with my example
When I selected Nike on sheet 1 his conversion rate is 0.25, all the details in sheet 1 i do get from sheet 2.
So conversion rate for Mike is 0.25 which is last so it should be red.
If I have selected Antha on sheet 1 then conversion rate is 100% then conditional formatting should be green.
Hope I explained correctly. The data on sheet is from sheet. please help
Good day ramnaidu
Forgot to say I am using excel 2007.
