Conditional formating in cells that contain two values from two other cells
giorgiokatr
Hi there i have a series of cells that each contains two values from two other cells
Α Β C
1 141 11 141 (11%)
2 144 13 144 (13%)
i use the function =A1&"("&B1&")"
is there any way to apply conditional formating to cells C1 and C2 based on the percentage value?
Hi Giorgio .
Since the percentage values are just taken from column B , we can certainly apply conditional formatting to the cells in column C based on the values in the corresponding cells in column B ; you need to specify the kind of CF that you want applied.
thanks narayank991!
awesome!
only a question
why did you set
=B1=MAX($B$1:$B$2)
and not =MAX($B$1:$B$2)
why do you have B1 as a benchmark?
also unfortunately it does not work if values $B$1:$B$2 are in another sheet!
Hi Giorgio ,
What we are telling Excel is that if the cell to the left of the current cell in column C is having the maximum value within column B , then color the current cell in column C.
Since we have used B1 , and not B$1 , as we go down , Excel internally changes the CF formula to :
=B2 = MAX( $B$1:$B$2 )
even though the CF formula will not change , since it has been applied to the range C1:C2 ; only if you copy the format from one cell to the other does the CF formula change.
Thus , if you had initially applied the rule to only cell C1 , and then copied the formatting rule to C2 , you would see the CF formula for C2 as :
As far as your second question is concerned , CF rules do not work with other sheet references , but the way around this is to use defined names or named ranges ; these can then be applied to CF rules.
See your file now.
