Complex formula with IF & VLOOKUP functions..help
rfreeman
Hello I need help in creating a formula that looks up a tariff and cross references it with 1 of 3 usage scenarios to return a monthly fee.
As per the attached the user would enter a usage value in B1, and select the Tarriff in B2.
Dependign on their data entry the formula needs to lookup the usage/tarrif in B1&B2 and cross reference the table in E1:I22, and return the applicable monthly fee for the usage and tarriff.
I have tried several IF functions and cannot get it to work, can someone please explain the best method?
  • TEST CASE HELP.xlsx
As a follow on I have written the following formula, however this is quite long and only looks up 1 of the 7 tarriffs.
=IF(AND($B$3="NSP56",$B$1>=0,$B$1<=2000),S3,IF(AND($B$1>=2001,$B$1<=5000),S4,IF(AND($B$1>=5001,$B$1<=9999999999),S5,"")))
Thanks for the response.
One of my collegues actually just responded and supplied a very easy formula using the SUMIF formula that i thought i should share.
This works really well
=SUMIFS(I3:I23,F3:F23,B2,G3:G23,"<"&B1,H3:H23,">="&B1)
