Compare two columns for a specific project
prasadsury
Hello All,
Can one of you please help me with a solution for the following problem in excel:
I am comparing an Intercompany report which has the following columns:
1) Company Code
2) GL Account
3) IC Partner
4) Project Number
5) Closing balance
What I will need is in Col H, will need a formula to check if the Company code & IC partner is used accurately for a specific project.
I am working on a data set that is 3000 lines so any quick help will be greatly appreciated.
Thanks,
Prasad
what are you checking against ?
itself
can you provide examples of correct and incorrect entries
I am checking it for a project number
For project aa11 Company code in row 2 is used as an ICP in row17 and ICP in row 2 is used as company code in row 17 (referring to the excel file)
so should the project number have the same codes
a countifs() should work
=IF(COUNTIFS($D$2:$D$17,D2,$A$2:$A$17,"<>"&A2,$C$2:$C$17,"<>"&D2),"check","")
but they are all wrong - from what i can see
the Company Code , ICP and Project - should always be the same
is that what you meant
I changed a couple of the rows to be the same codes and highlighted orange
Hey ETAF,
Thanks a lot for your swift response.
I actually meant that for aa11 project my row2 had company code as 120 and ICP as 270 but in row 17 whatever that was ICP in Row 2 (which is 270) is my company code and vice versa, so I need this check in column H. So in the sample that I shared all my combinations are would be correct (going by my above logic).
Please do let me know if this clarifies your query and appreciate if you can please help.
Thanks,
Prasad
how about
=IF(OR(COUNTIFS($D$2:$D$17,D2,$A$2:$A$17,A2,$C$2:$C$17,C2)=0,COUNTIFS($D$2:$D$17,D2,$A$2:$A$17,C2,$C$2:$C$17,A2)=0),"check","")
i changed a row -so it does not match
may need some more examples - of wrong - so can test as 3000 lines may not work
