Combine Vlookup and Countif...I need help please!!!
butterboxbaby14
I would like to get assistance on the attached sheet. I am trying to get the number of Y's and N's per Country and be displayed in the Summary tab.
I hope someone can help me on this. Been trying several and can't seem to get it running.
Thanks.
  • Sample Sheet.xlsx
Do you want to add both column Y and N against one country?
For eg: South Africa --> Total Y in column D is 11 and in column E is 9. So in Summary Sheet against South Africa you want 20 as result in Y?
Well I intend to count the Y's and N's in Column D and then do the same for column E. If you show me how you do it for column D for now, I can study and do it myself for the rest :)
Just a quck question to add. If I would want to have the Raw Data act as a database wherein continuous data is being added to the sheet(so row number increases), is there a way to have the formula recognize the whole column instead of just what is currently in it?
Please see attached sheet, its simple formula "countifs"
Press like button if job done
Just a quick question to add. If I would want to have the Raw Data act as a database wherein continuous data is being added to the sheet(so row number increases), is there a way to have the formula recognize the whole column instead of just what is currently in it?
