Column Header basis Max Values
chirayu
Hi Guys,
I have a set of data which has:
- Vendor names in column A
- Occurrence data for reasons of some sort of non compliance in other columns
What I would like to achieve if possible is to find:
- Highest Value for a given Vendor
- 2nd Highest Value for the same Vendor
- 3rd Highest Value for the same Vendor
Basis these Values I would then like to know the column Headers for that column for that specific Vendor.
I know that The LARGE formula can be used to find such Values. But This would only really work if I had only unique numbers. E.g. 2 columns could have the same Value so finding the column Header is difficult.
This is also further complicated by the fact that a given Vendor may not necessarily have 3 reasons. They might have just 1 or 2.
I have attached a sample file for the same & hope you guys can help.
Here you go.. here is the spreadsheet updated with the formula to fetch 1st, 2nd and 3rd highest values.
Hope it helps!!
Thanks,
Ramesh Kumar.P
Hi Ramesh, Thanks for the quick reply but I don't need the actual Values. As stated in the post/file. I need the corresponding column Header for that value.
Thanks Ramesh for your quick response, checked the output. It seems it is not outputting correctly.
For example select Vendor A. Comment 3 should be Reason 10 not Reason 5. I believe this is because of the -1 argument in the formula.
Secondly I also noticed that in the instance that Multiple columns have the same value, it disregards other matching values & moves onto the next lowest - this can be seen for Vendor B. Where Comment 3 picks Reason 2 instead of Reason 5 or 6
