column comparison issue between two workbooks
Status
Not open for further replies.
klpw
Hi guys,
I want to compare column between 2 workbooks. If the data from column D in fortest1.xlsx and column F in tested.xlsm are matched, then do nothing. If they are not matched, then data from column A to C in fortest.xlsx needs to be copied and pasted to column C to E in tested.xlsm. I've created the code and it runs without error but it doesn't generate any result at all.
Thanks in advanced.
  • fortest1.xlsx
  • tested.xlsm
Status
