Code help - macro to copy a worksheet to multiple workbooks without opening
Hi All,
I have one worksheet that need to be copied to 10+ workbooks saved in a folder. I don't want to open the target workbooks for copying purposes. I have the following macro to copy the activesheet and can only select one workbook. Can you help me to increase the selection to multiple workbooks to copy the activesheet to all the workbooks in a folder.
Public Sub CopySheetToClosedWorkbook()
    Dim fileName
    Dim closedBook As Workbook
    Dim currentSheet As Worksheet
    fileName = Application.GetOpenFilename("Excel Files (*.xlsx), *.xlsx")
    If fileName <> False Then
        Set currentSheet = Application.ActiveSheet
        Set closedBook = Workbooks.Open(fileName)
        currentSheet.Copy After:=closedBook.Sheets(closedBook.Worksheets.Count)
        closedBook.Close (True)
Not without opening the Workbooks where the sheet needs to be copied into.
Copies the first sheet from all workbooks, except from this workbook which has the code in it, in the same folder where this workbook has been saved.
Sub Copy_Sheet1_Into_Master()
Dim mydir As String, myfile As String, mybook As Workbook, j As Long
    j = 0
    mydir = ThisWorkbook.path & "\"
    myfile = Dir(mydir & "*.xl*")
    Do While myfile <> ""
        If myfile <> ThisWorkbook.Name Then
        Set mybook = Workbooks.Open(mydir & myfile)
            j = j + 1
            mybook.Sheets(1).Copy After:=ThisWorkbook.Sheets(ThisWorkbook.Sheets.Count)    '<--- Change the 1 to the sheet number (from the left) that needs copying into Master
                ThisWorkbook.Sheets(Sheets.Count).Name = "New Sheet " & j
        mybook.Close False
        myfile = Dir()
    Loop
