Code for Disable Right click on Excel Slicer in Protected Sheet
Akash_Patel
My Query
I have an Excel file which has a dashboard and it has multiple slicers which fetch data from one pivot table. All the slicer and Pivot Table are linked with each other. When I have protected my file with the allowance of pivot and filter, All slicers can be still excess by Right click. So that cut, Remove, Change Remote Connection and all other options can be done by selecting Right click on slicer.
Now I don't want to allow the right click on any slicers of my workbook and still the slicers can work as normal. How can I Do it?
Can anyone help me with the code for this.
Akash_Patel
As written in many Forum Rules:
Akash_Patel
If You read again above text about Cross-Posting
The 1st line something basic.
2nd line ... You seems to missed two times,
3rd line ... should happen ... after ... those previous.
You seems also missed to read and follow
How to get the Best Results at Chandoo.org from
Do Yo have a clear image - how could others test Your case? ... without any sample file.
About Your Yes Definitely...
... Have You checked other Forums replies?
Yes Definitely, I will post the solution here as well if I will get it. So that it can be useful to others as well.
