Choose function is not giving result for Static Array input
Junarkar
Hi
I have written below formula;
INDEX(CHOOSE(WEEKDAY(TODAY()),WeekNumber),WEEKDAY(C$10))
WeekNumber is a static array. It contains below info.
{"WeekDay1","WeekDay2","WeekDay3","WeekDay4","WeekDay5","WeekDay6","WeekDay7"}
WeekDay1,2,3 etc. are also static arrays. All of them contains numbers.
I want choose function to return the array name according to index number provided by Weekday().
Sample file is attached.
  • Sample File.xlsm
Formula syntax requires each value/array to be separated by comma.
i.e. =CHOOSE(index_Num,Item1,Item2,Item3...)
You can't use it like below...
=CHOOSE(2,{"X","Y"})
This will result in error as 2nd item to pick isn't present. While 1 in index_num argument will work as Item1 = {"X","Y"}.
Thanks Chihiro for the fast response...!!! But need little more help please.
Now I have changed formula as below;
($G21*INDEX(INDEX(WeekNumber,WEEKDAY($N$1)),WEEKDAY(C$10)))/100
But still returns #VALUE! error. When evaluated, what I understood is that;
* First second Index function - INDEX(WeekNumber,WEEKDAY($N$1), returns the correct array name. WeekDay5 in this scenario.
* Second Index function is not recoganising this as an Array instead consider it as a text string.
Please help.
  • Sample File.xlsm
You'll probably have to nest the inner INDEX in INDIRECT. Since name as string can't directly be used to reference named range.
=($G21*INDEX(INDIRECT(INDEX(WeekNumber,WEEKDAY($N$1))),WEEKDAY(C$10)))/100
Hmm, you may need to build your named ranges using actual ranges.
I just realized hard coded names can't be referenced using INDIRECT.
Ex: Add sheet "Names"
In A1:E1, enter WeekDay1 ~ WeekDay5
Then in rows below values for each name.
Name A2:A8 as WeekDay1, B2:B8 as WeekDay2 etc.
Now you can refer to it using Indirect.
Alternatively, add a new name WeekEval that refers to this formula
=EVALUATE(INDEX(WeekNumber,WEEKDAY(Week!$N$1)))
Then in C11
=($G21*INDEX(WeekEval,WEEKDAY(C$10)))/100
Wow...!! That worked like a charm... I put it in a single line though.
=($G21*INDEX(EVAL(INDEX(WeekNumber,WEEKDAY($N$1))),WEEKDAY(B$10)))/100
Thanks a lot Haz....
