Charts Named ???? VBA Script to change (Not manual changes) over 150 charts.
ianb
Hi All,
I have charts named 1, 2 1894, 2347 to name a few on numberous worksheets.
I would like to number each chart 1-5 or 1-9 on each worksheet.
I could goto LAYOUT and rename each one individually.
Is it possiable via a VBA script to goto each worksheet select each name and rename is sequence.
5 becomes 1
1878 becomes 2
5434 becomes 3 then next work sheet
7 becomes 1
1524 becomes 2
9984 becomes 3
Then I can run a script to change the themes, effect etc as i know who many charts are on each worksheet.
Ian.
Hi, ianb!
Give a look at this file:
https://dl.dropbox.com/u/60558749/Charts%20Named%20____%20VBA%20Script%20to%20change%20%28Not%20manual%20changes%29%20over%20150%20charts.%20%28for%20ianb%20at%20chandoo.org%29.xlsm
The procedure RenameCharts renames each chart of each sheet with numbers from 1 in advance. This is the involved code:
[pre]
Sub RenameCharts()
' constants
' declarations
Dim I As Integer, J As Integer, A As String
' start
' process
With ActiveWorkbook
For I = 1 To .Worksheets.Count
With .Worksheets(I)
For J = 1 To .Shapes.Count
Debug.Print I, .Name, J, .Shapes(J).Name, .Shapes(J).Type
If .Shapes(J).Type = msoChart Then .Shapes(J).Name = CStr(J)
Next J
Next I
' end
[/pre]
Just advise if any issue.
Regards!
Also I have been working on code to change :
Colour Scheme
Theme Effects
Theme Fonts
I am writing macros that are long. know of a short way to do this for all worksheets
I have two macros one for dark and one for light.
e.g.
' Colour Scheme
' ActiveWorkbook.Theme.ThemeColorScheme.Load ( _
' "C:program FilesMicrosoft OfficeDocument Themes 12Theme ColorsUrban.xml")
' "C:program FilesMicrosoft OfficeDocument Themes 12Theme ColorsMetro.xml")
' "C:program FilesMicrosoft OfficeDocument Themes 12Theme ColorsMedian.xml")
"C:program FilesMicrosoft OfficeDocument Themes 12Theme ColorsTechnic.xml")
' "C:program FilesMicrosoft OfficeDocument Themes 12Theme ColorsEquity.xml")
' "C:UsersKalaniahAppDataRoamingMicrosoftTemplatesDocument ThemesTheme ColorsSilk.xml" _
' Theme Effects
ActiveWorkbook.Theme.ThemeEffectScheme.Load ( _
"C:program FilesMicrosoft OfficeDocument Themes 12Theme EffectsApex.eftx")
'Theme Fonts
ActiveWorkbook.Theme.ThemeFontScheme.Load ( _
"C:program FilesMicrosoft OfficeDocument Themes 12Theme FontsTechnic.xml")
'Chart Configurations - Must be numbers in Layout Section 1-21 examples.
Sheets("Dashboard (????????)").Select
Range("A6").Select
ActiveSheet.ChartObjects("Chart 1").Activate
ActiveChart.ClearToMatchStyle
ActiveChart.ChartStyle = 18
ActiveSheet.ChartObjects("Chart 2").Activate
ActiveSheet.ChartObjects("Chart 3").Activate
ActiveSheet.ChartObjects("Chart 4").Activate
ActiveSheet.ChartObjects("Chart 5").Activate
Ian.
Hi, ianb!
Glad you solved it. Thanks for your feedback and for your kind words too. And welcome back whenever needed or wanted.
For the first part, you can write your code in this way too, it's clearer to read:
[pre]
Sub x()
' constants
Const ksPath1 = "C:Program FilesMicrosoft OfficeDocument Themes 12Theme Colors"
Const ksPath2 = "C:UsersKalaniahAppDataRoamingMicrosoftTemplatesDocument ThemesTheme Colors"
' declarations
' start
' process
With ActiveWorkbook.Theme.ThemeColorScheme
' choose one
.Load (ksPath1 & "Urban.xml")
.Load (ksPath1 & "Metro.xml")
.Load (ksPath1 & "Median.xml")
.Load (ksPath1 & "Technic.xml")
.Load (ksPath1 & "Equity.xml")
.Load (ksPath2 & "Silk.xml")
' end
[/pre]
Regards!
Many Thanks again. I have an idea. do you know how to pick one at random from the list or goto 1 to 5 in order.
' constants
Const ksPath1 = "C:program FilesMicrosoft OfficeDocument Themes 12Theme Colors"
' declarations
' start
' process
' choose one
' end
Having fun tonight with this... until the movie is ready.... I watch Supernatural (The two borthers season 7) very funny.. must watch from the start season 1..
Hi, ianb!
For getting a random value between 1 and 5 you might use:
I = Int(Rnd()*5)+1
Define I previously as integer
Regards!
Just a note that the VBA helpfile topic on Rnd() suggests:
I = Int(Rnd()*5+1)
which gives slightly different results. For example if Rnd() returns 0.2
