Changing Fonts and Font sizes at once
mithil1
If there are 30 tabs in one file how do I change the font sizes and type for all at once and not manually going into each and changing it ?
Hi, mithil1!
Just select 1st tab.
If all are contiguous press Shift and select 30th tab; if not, press Ctrl and select each of the other 29.
Then select all cells (click on rectangle at top of rows no. and at left of cols. letters), and change the font.
Regards!
Hi, mithil1!
Glad you solved it. Thanks for your feedback and welcome back whenever needed or wanted.
Regards!
