Cell referencing problem
Nicki
Hi, Could you please help changing this working time sheet in a way that basic user can copy and paste template below the the next one without changing anything else. I know it is easy to do it by creating one sheet for each staff, but having so many staff it is not easy to have 100 tabs across. it has to be at least 10 staff in one sheet. nay redesign or using VBA will be appreciated.
1- Copy and paste is easy for adding new staff, currently copy and paste needs adjusting cell references for column J and K which connected to B and E.
2- Also avoid deleting cells containing formula I have to luck the cells but then it will not let user to add rows if needed
Any improvement formula please. Thanks indeed.
  • Clerical TIL- V1.xls
Hi Nicky
I would recommend getting out of compatibility (xls) mode and using the Tables for more than the pretty stripes (using an xlsx format).
I have replaced your direct cell referencing with Structured References and the copy / paste operation then seems to work fine. I selected entire rows so that the row spacing was replicated and changed the table name to apply to the staff member once the table was copied.
  • Clerical TIL- V1 (pb).xlsx
