Agreed Ctrl + ~ makes it work, but that mode is not normal, correct?In your test file, I used the CTL and tilde and it immediately aligned properly. When I create a new spreadsheet and attempt to align the records as you have, it does so properly. I am running XL2016 and don't seem to have an issue. I wonder if you have a corrupt spreadsheet. Is this an issue on all worksheets or just the one in question. I don't think its a bug.
I don't recognize where that is.
Your sheet is not in normal mode. AlanSidman's response is spot on.Agreed Ctrl + ~ makes it work, but that mode is not normal, correct?
The confusing part is I am sure I didn't check [Show Formulas]....I opened a new file.Your sheet is not in normal mode. AlanSidman's response is spot on.
View attachment 45158View attachment 45158
If I open attached file then this toggle button is ON which means if you enter a formula e.g. "=KilRoy was here!" then you will see "=KilRoy was here!" which is not normal. In normal mode one should see only Text without Quotes i.e. KilRoy was here!.
