Basic Problem involving Sum
Abhiroop
Hi Guys,
I have a problem which seems rather easy, however I can't arrive at the solution.
Suppose you have two cols. Column A contains around 3000 names. And corresponding to every name, you have a certain value assigned which is in column B.
Now, I sort column B in descending order. I now want to add up the values in Col. B to figure out which rows make up 70% of the total value.
Suppose i see that the range (B2:B976) represents 70% of the total value.
Then I would like to add up this range (B2:B976) to find out the exact value.
The 70% value should be in a cell so that i can keep changing the number as per my convenience to probably 80% or 50% etc.
Is there a simple way to do this?
Thanks in advance!
Hi Abhi,
please find attached one give required % in cell c1.
  • Solutions.xlsx
Hi Bhawani,
Thanks for your help! I am not able to understand the process.
PFA a file that i have uploaded showing an example of the problem with the steps involved. Please let me know if this would help?
Cheers!
  • Problem.xlsx
Abhiroop ,
I have used simple conditional formatting & sum formula to derived at following sheet.
Request you to please see and suggest this meets your requirement or not.
  • Problem - Solution.xlsx
PFA... If this match your requirement where
1. red highlighted cell is showing total of column B
2. yellow highlighted cell is showing % on which we will work on(getting range) 3. we can change % here from 70% to 80% or 50% or whatever you wish to.
skyblue highlighted cell will show the range for respictive required % range
4. Column D shows running total and will show all the row value for required %
In attached file minimum % value is taken.
  • Solutions.xlsx
Guys!
Thank you everybody for your awesome replies and all the help that you provided!
Haseeb, your formula really helped out and it solves the problem in a single step! Thanks a ton!
Swapnil and Bhawani, thanks a lot for your inputs! Really appreciate your help and multiple inputs and the time you took in trying to help me out!
Cheers!
