Average function help
just need small help on Average function, finding difficulties to do average on timings in the enclosed excel sheet.
I want the average of g6:g31 in cell N6, however its give error #DIV/0...
Please help
Mohamed Sameer
  • Analysis Report - 04 Feb 2018.xlsx
it is simple average, i will take the average handling time for each 15 mins interval for all line and with the help of Average handling time i will able to know how much staffing required as per the data in excel file.
Hi Mohamed, you are trying to do an average of text?
If you would format your column to time, do a text to column of that column, then the average simply works.
  • Copy of Analysis Report - 04 Feb 2018.xlsx
Dear GraH,
Thank you for your help, it was really tricky for me to understand, and I know I would get the solution from chandoo forum with great people helping.
you are the best.
Thanks you
