Auto fill : Need Help
Hi Solvers
When i drag auto fill option is not visible ( That "+"sign usually appears in bottom right corner of cell and it is used for draging formulas and numbers )
Where can i found the option to sort it down -
Ps : In 2003 & 2007
HI Senthil,
Sorry, currently I don't have Excel proposed version.. :)
Can you please go to VBA (Alt + F11) >> Immediate Windoe (Ctrl + G)
and type
Application.CellDragAndDrop = TRUE
It will solve the problem.
Deb
Hi Senthil,
I got it..
Tools > Option > Edit > Allow Cells Drag & Drop (CheckBox)
http://www.hotexcel.com/wp-content/uploads/2010/11/MS-Excel-2003-enable-AutoComplete-feature.jpg
Deb
In 2007
Check Enable Fill handle...
http://www.java2s.com/Tutorial/Microsoft-Office-Excel-2007Images/To_Turn_On_Autocomplete_Option___Click_Advanced_Select_Enable_Autoco.PNG
