Applying ID to get web data Using VBA
shahin
Hi there! Hope you all are doing well. So far when I worked with vba to fetch web data I used either "class" or "tag" name to parse that. But, in case of applying "ID" I got stuck. Using class name I can get the data from this site but when I trend to apply "ID" to get the same it throws error. Perhaps I'm doing something wrong which I can't identify. Hope somebody out there will help me to accomplish this. Thanks in advance.
Sub FashionStuff()
Dim http As New MSXML2.XMLHTTP60, html As New HTMLDocument
Dim elements As Object, element As Object, post As Object
With http
    .Open "GET", "https://www.sephora.ae/en/stores/", False
    .send
    html.body.innerHTML = .responseText
Set elements = html.getElementById("mm-makeup-nav-item")
Set element = elements.getElementsByTagName("a")
    For Each post In element
        x = x + 1
        Cells(x, 1) = post.href
    Next post
    Set http = Nothing: Set elements = Nothing: Set element = Nothing
Thanks sir for the link. I've got it solved with another site.
Sub TorrentData()
Dim http As New MSXML2.ServerXMLHTTP, html As New HTMLDocument
Dim topics As Object, topic As Object, post as object
With http
    .Open "GET", "https://www.yify-torrent.org/search/1080p/", False
    .send
Set topics = html.getElementById("main")
Set topic = topics.getElementsByTagName("img")
    For Each post In topic
        x = x + 1
        Cells(x, 1) = post.src
    Next post
Set html = Nothing: Set topics = Nothing: Set topic = Nothing
OR
Sub TorrentData()
Dim topics As Object, post As Object
With http
    .send
Set topics = html.getElementById("main").getElementsByTagName("img")
    For Each post In topics
        x = x + 1
    Next post
