Add another VBA code to current VBA script - Lock Cells Immediately
MaunishP
Hi Team,
I have a VBA code which allows me to double click and insert timestamp in Column K & L, however every time I insert data in K1&L1, it should get locked and no one should be able to edit data. However if i move to next row then I can enter data in K2&L2 and follow same process Lock --> Next Cell then K3&L3 and go on till last count.
Once cells are locked no one should be able to edit it or delete them. Every new row i should be able to insert timestamp and once timestamp is insert file use to get closed.
Below given is VBA code for double clicking time entry
Private Sub Worksheet_BeforeDoubleClick(ByVal Target As Range, Cancel As Boolean)
Dim rng As Range
Set rng = Range("TimeEntry")
If Target.Count > 1 Then Exit Sub
If Not Intersect(Target, rng) Is Nothing Then
Cancel = True 'stop the edit mode
With Target
If .Value = "" Then
.Value = Time
.Offset(0, 1).Activate
Note that you would need to start with the TimeEntry's Locked status being unchecked.
Then, this code will do what you state.
Dim rng As Range
    'Unprotect the sheet, since we need to change a cells protection
    Me.Unprotect
    With Target
        If .Value = "" Then
            .Value = Time
            'Change cell's protection status
            .Locked = True
    'Re-lock the sheet
    Me.Protect
Hi Luke, however rest columns are also locked i cannot write to edit them.
Please find attached.
I want only column K & L to be locked once data is inserted
  • TimeTrack.xlsm
You will need to change the protections status on those other cells to be unlocked as well.
So, if you were starting from a clean slate:
1. Unprotect the Sheet
2. Select all cells on the sheet
3. Format cells, Protection - Locked = Unchecked
4. Protect Sheet
Everything is all setup now so that you can edit any cell except where macro places timestamp.
