VBA Code to look at range of cells in row and perform paste to another sheet based on cell values
Jack Farhi
This is some what of a challenge for me - have been doing VBA for a while so bear with me please. Any help would be appreciated. What i'm trying to do is to take a named range and take 2 values from each row and perform a function. With the value in Column I, i want to paste that to a new row on another sheet and use the value in Column F as the number of times to paste the value from Column I on the other sheet in the adjacent cells (on the same row). For example. if the value in Column F is $95,000 and the value in Column I is 12, then i want to past the $95,000 12 times on the new sheet on a single row in columns A through L. I believe that this is a nested VBA function to handle the read for each of the 2 columns in the sequential rows at the source and then paste the results to the destination sheet and then cycle through again to the next row at the source and paste on the next row at the destination. Here's what i have thus far (far from finished). Any help would be appreciated!!!
Sub DeliveryDatesInflowOthers()
' DeliveryDatesInflowOthers Macro
    Dim IngCol As Long
    Dim i As Integer
    Dim n As Integer
    IngCol = Range("XCol2")
    CleanSlateInflowsOther
    NumPMTs = Range("PmtQty")
    InflowSpacing = Range("PmtSpacing")
    Sheets("Inflows - OTHER").Select
    Range("I3").Select
    Selection.Copy
    Sheets("Cashflow").Select
    For n = 1 To 20
    Cells(44, IngCol).Select
        :=False, Transpose:=False
    For i = 1 To NumPMTs - 1
    ActiveCell.Offset(0, InflowSpacing).Activate
    Next n
    Sheets("Inflows").Select
    Range("A1").Select
    Range("A1").Select
I know that this works for a single row from source sheet. I tested it using single cell ranges - just need to cycle through this for each row at the source and to the destination. Ive coded the number of rows at the source from 1 to 20 - just an fyi.
First of all, welcome to the forum :)
Please refer to the sample attached:
Sub CopyRng()
    Dim lrow, dest_lrow, n As Integer
    Dim c As Range
    lrow = Sheets(1).Cells(Rows.Count, "F").End(xlUp).Row
    For Each c In Sheets(1).Range("F1:F" & lrow)
        n = c.Offset(, 3).Value
        dest_lrow = Sheets(2).Cells(Rows.Count, 1).End(xlUp).Row + 1
        Sheets(2).Range(Sheets(2).Cells(dest_lrow, 1), Sheets(2).Cells(dest_lrow, n)).Value = c.Value
    Next c
Let me know if this helps
Sub CopyRng()
    Dim c As Range
    Next c
PCosta87 - YOU ARE A GOD!!! Looks good. Going to insert into my workbook and fine tune a bit - Sir - you are a scholar and a gentleman - my respect and thank you to you sir!!!!
So quick question, how can i use vba to specify which row to start the paste for sheet 2? Also, can i use a variable to declare which column to start on for each row that i paste in sheet 2?
You are welcome... I'm glad I could help :)
how can i use vba to specify which row & column to start on sheet 2?
In this line:
dest_lrow is the last used row of the destination sheet and 1 is the column (1 stands for column "A").
dest_lrow basically detects the last used cell in the column specified (in this case "A" or 1).
Changing 1 to 2 will start at column B, below the last non empty cell... if you do this you will also need to adjust the end cell by adding the same value:
Example:
Imagine you wish to start at column D:
Sheets(2).Range(Sheets(2).Cells(dest_lrow, 1+3), Sheets(2).Cells(dest_lrow, n+3)).Value = c.Value
The row is dynamic so if you use a column where row 10 is the last one <>empty, it will start placing the values at row 11.
I suggest you fiddle with the code yourself and see the results of your changes... it will start to make sense :)
I'm beginning to understand now - thanks. Just one problem - when i insert the last line you specified it does not cycle through the rest of the values on sheet 1. Let's say that i add a third column in Sheet 1 that specifies which column to start in, how would that work with the line below?:
Ok - so let me clarify - i would like to define the starting row/column in destination sheet 2 for the start of the paste and then for each of the following rows in sheet 2, i would like to specify the starting column based on a value - so i tried to make the changes that you described above and it only worked for 1 line - i fiddled with the code a bit but went down a rathole -lol. Any other advice would be greatly appreciated!
Please upload a sample Excel file and I will gladly take a look at it.
What you want may need some tweaks or a complete overhaul of the current code...
Sure thing - i understand. Attached is the sample file you requested. Looking to line up the output on (2) into the correct column specified on (1). Thanks for your help!!!
It's great!! I just want to place it in something other than column A. - i would say column D as the starting point on (2)
It's great!! I just want to place it in something other than column A. - i would say column D as the starting point on (2). So basically, shifting the entire section over to cell D5 as the starting point for the columns and the rows.
PCosta87 - Eureka!! You sir are to be respected and celebrated. I thank you sincerely for your efforts - it's right on the nose. How may i repay you sir?
