Using a similar technique to the index function in vba
CLoos
I can't seem to get started on this macro, maybe someone can give me a hint. What I want to do is when the user pushes the "schedule" button on the input sheet the macro will loop through a series of dates and values (from sheet3) and place the values onto the schedule worksheet. To do that the macro will need to identify the corresponding date and plant on the schedule sheet. So I am not sure how to do that. Do I set up a range of variables?
Thanks for any advice. No code written but worksheet attached.
Try
Sub test()
    Dim a, i As Long, ii As Long, dic As Object
    Set dic = CreateObject("Scripting.Dictionary")
    dic.CompareMode = 1
    a = Sheets("sheet3").Cells(1).CurrentRegion.Value
    For ii = 1 To UBound(a, 2) Step 2
        Set dic(a(1, ii)) = CreateObject("Scripting.Dictionary")
        For i = 2 To UBound(a, 1)
            dic(a(1, ii))(a(i, ii)) = a(i, ii + 1)
    Next i, ii
    With Sheets("Schedule").Cells(1).CurrentRegion
        .Offset(1, 1).ClearContents: a = .Value
            If dic.exists(a(i, 1)) Then
                For ii = 2 To UBound(a, 2)
                    If dic(a(i, 1)).exists(a(1, ii)) Then a(i, ii) = dic(a(i, 1))(a(1, ii))
        .Value = a
Thank you! I can work with this! I won't be able to test it until next week but I am sure it will work. I have never used the create object (scripting.dictionary) before, it is a bit over my head but I am anxious to learn this. Again Thanks!
