Problems with xlsb format
mehman
I have a template in xlsb format ( lets call this t.xlsb) that I use to create reports using Access 2007 & vba. This template has 2 sheets, each with a pivot table.
Whenever I make changes to the template and run the reports, the reports get corrupted. So I do the following steps
1. save the template as another one (lets call this one the t1.xlsb).
2. Rename t.xlsb to new.xlsb.
3. rename the t1.xlsb to t.xlsb
4. delete new.xlsb.
I repeat these steps every time I make changes to the template, to avoid corruption of reports.
Any suggestions to avoid these 4 steps after making changes.
Thanks in advance.
Mehman
Backup the file
Open the file
Ctrl+Alt+Shift+F9
Save the file
Close excel
Open the File
See if that helps
If that doesn't
When you open the file, select File Open
Select the file Don't press Open
Select the small drop down arrow next to Open
Select Open & Repair
See if that helps
