Problem with VBA coding, need another POV
cparks
I have a button that when clicked, it copies to the last row of data, then pastes it into another worksheet.
My problem is it gives me an Error Message dealing with the "paste" section of the code.
And it pastes under A2, it needs to be in B2.
I just want to get rid of all the blank cells under the last row of data when pasted.
Sub Button10_Click()
Dim copySheet As Worksheet
Dim pasteSheet As Worksheet
Dim Last_Row As Long
Set copySheet = Worksheets("Data Entry Sheet")
Set pasteSheet = Worksheets("Main Data Sheet")
Last_Row = Range("G2").End(xlDown).Offset(1).Row
copySheet.Range("G2:M2").Copy Range("G" & Last_Row)
pasteSheet.Cells(Rows.Count, 1).End(xlUp).Offset(1, 0).PasteSpecial xlPasteValues
Suggestions? Where did I go wrong?
Thanks.
Thanks.
Hi @cparks
Try it like this:
'    Last_Row = Range("G2").End(xlDown).Offset(1).Row
    Last_Row = Columns("G").Cells(Rows.Count).End(xlUp).Row + 1
    pasteSheet.Cells(Rows.Count, 1).End(xlUp).Offset(1, 1).PasteSpecial xlPasteValues
The problem was that you were doing End(xldown) on G2 and you probably don't have any data after G2 so it returns an error... also you just need to input the paste destination once, either after .copy in the same line or on the line after
Let me know if you have any further questions
Right on the money @PCosta87 ! You're 2/2. Again, bravo!
Sorry for the other message...I kept looking the code over and over and I accidentally typed in "G"'s instead of "C"'s. My mistake. I deleted the message but looks like it was too late.
Sorry about that. You had it all along! I can get some sleep now. Again, much appreciated.
You are welcome ;)
You know what @PCosta87 . I'm not going to bother you with this. Youve done great and i found out what it was. No issues. Going to bed. Again, thanks :)
Just replace:
with
    pasteSheet.Cells(Rows.Count, 2).End(xlUp).Offset(1, 0).PasteSpecial xlPasteValues
If you need anything else just ask ;)
