Pls help me with vba code to create folders and subfolders from excel cells
Hi, Hari7000!
As a new user you might want to (I'd say should and must) read this:
http://chandoo.org/forum/forums/new-users-please-start-here.14/
And regarding your issue, please elaborate a bit more, describe more precisely your requirement and eventually consider uploading a sample file (including manual examples of desired output if applicable), it'd be very useful for those who read this and might be able to help you, relieving the contributor of having to build a test file, if necessary. Thank you.
Regards!
I Need create folders and subfolders from excel list like below
Main Sub1 Sub2
SET 1 ABC AA
SET 2 DEF BB
SET 3 GHI CC like goes on till sub folders up to 10
Hi I don't know about subfolders but I use below code if I have to create multiple folders at once.
Sub CreateFolders()
Dim Cell As Range
Dim MyPath As String
Dim MyRange As Range
MyPath = ThisWorkbook.Sheets(1).Cells(2, 1)
Set MyRange = Range(Cells(3, 3), Cells(3, 3).End(xlDown))
For Each Cell In MyRange
    MkDir MyPath & "\" & Cell.Value
    If Err.Number > 0 Then
        Cell.Offset(0, 1).Value = "Some error occurred"
Next Cell
With Regards
Rudra
Sub CreateFolders()
Dim Cell As Range
Next Cell
With Regards
Rudra
Thank you Rudra
Thank you Rudra, i got a code from google search, Pls help me with inputbox for giving path for the location
Below is the code (Need inputbox for the highlited)
Sub startCreating()
Call CreateDirectory(1, 1)
Sub CreateDirectory(ByVal row As Long, ByVal col As Long, Optional ByRef path As String)
If (Len(ActiveSheet.Cells(row, col).Value) <= 0) Then
Exit Sub
Dim sDir As String
If (Len(path) <= 0) Then
path = ActiveSheet.Cells(row, col).Value
sDir = "E:\" & path
sDir = path & "\" & ActiveSheet.Cells(row, col).Value
If (FileOrDirExists(sDir) = False) Then
MkDir sDir
If (Len(ActiveSheet.Cells(row, col + 1).Value) <= 0) Then
Call CreateDirectory(row + 1, 1)
Call CreateDirectory(row, col + 1, sDir)
Function FileOrDirExists(PathName As String) As Boolean
'Macro Purpose: Function returns TRUE if the specified file
' or folder exists, false if not.
'PathName : Supports Windows mapped drives or UNC
' : Supports Macintosh paths
'File usage : Provide full file path and extension
'Folder usage : Provide full folder path
' Accepts with/without trailing "\" (Windows)
' Accepts with/without trailing ":" (Macintosh)
Dim iTemp As Integer
'Ignore errors to allow for error evaluation
iTemp = GetAttr(PathName)
'Check if error exists and set response appropriately
Select Case Err.Number
Case Is = 0
FileOrDirExists = True
Case Else
FileOrDirExists = False
End Select
'Resume error checking
On Error GoTo 0
End Function
Are you looking for something like this?
sDir = "E:\" & InputBox("Enter your Path", " Path Please")
P.S. I have not tested your code.
With Regards
Rudra
With Regards
Rudra
Thank for reply, bascially what i want is any user enter the path to create folders in desired location
in this code need to change path in coding, insted of that when we run the program to pushbutton, it has to ask the path to create a folders.
if time permits pls run the code, some times its working, somtime not
Thanks & Regards,
Hari.
I had once started on this concept 2-3 years back and never really finished on it. But I think the folder making part works (it at least worked for the directory structure I wrote). You can do any change to the code or improve as needed.
Read instructions carefully before implementing. Column A should be drive letter and each subsequent level should be just one row below.
If you run the code as it is with structure I have typed in it will give you fair idea of what to expect.
