PLEASE HELP! TOPIC - CRITERIA BASED VBA VLOOKUP
ahmed.sange
I'm looking for some assistance in developing a macro for the below:
  1. I have two workbooks (book1 & book2) with a primary key (i.e. a common column of data - i.e. item code). Both the workbooks are dynamic (i.e. there may be new columns and rows added onto both the workbooks). Book 1 contains the data/table from where I want to vlookup data onto book 2 based on conditions. Please view the attached 2 workbooks.
  2. I want the macro to find the 'month' in book1 and then vlookup that data onto the same month column of book2 based on the item code. (e.g. To vlookup august data on book2, I want the macro to find august on book1 and then vlookup data based on the item code)
  3. This is because there will be new columns (i.e. new month columns) added to book1 on a monthly basis.
Please help as all my attempts have failed.
Adding on to Deepak's idea, this macro does similar. Be sure to adjust names as needed
Sub RefreshValues()
Dim sourceName As String
Dim fPath As String
Dim shName As String
Dim lastRow As Long
Dim lastCol As Long
'What is name of source book?
sourceName = "Book1 - Sample.xlsx"
'What is name of sheet with data?
shName = "Sheet1"
'Where if file located? If not the same folder as this workbook, change this line
fPath = ThisWorkbook.Path
If Right(fPath, 1) <> "\" Then
    fPath = fPath & "\"
'Which sheet in this book gets values?
With Worksheets("Sheet1")
    'Define boundaries on this sheet
    lastRow = .Cells(.Rows.Count, "A").End(xlUp).Row
    lastCol = .Cells(1, .Columns.Count).End(xlToLeft).Column
    With .Range("I3", .Cells(lastRow, lastCol))
        'Use formulas
        .FormulaR1C1 = _
            "=INDEX('" & fPath & "[" & sourceName & "]" & shName & "'!R5C7:R1000C26,MATCH(RC2,'" & _
            fPath & "[" & sourceName & "]" & shName & "'!R5C2:R1000C2,0),MATCH(R1C,'" & fPath & "[" & sourceName & "]" & shName & "'!R2C7:R2C26,0))"
        'Make static values
        .Copy
        .PasteSpecial xlPasteValues
Sub RefreshValues()
Dim fPath As String
Dim lastRow As Long
Dim lastCol As Long
shName = "Sheet1"
    fPath = fPath & "\"
        'Use formulas
        .FormulaR1C1 = _
        'Make static values
        .Copy
Luke,
Mate. You're a genius. Been working at it for the past two weeks to no avail. You've done it in a flash. I'm a fan of you from today mate. Thanks a ton.
Deepak, Thank you once more mate. You directed me in the right direction.
Glad i joined this community of awesome people.
