Excel VBA : Need help
Tanushri_Kothari
Hi, need help on excel vba. I have attached an Excel workbook along with Access Database. Password to open the database is 1234. I have placed a button on the excel sheet1. If I click on that button, it should export the data from the access database onto a new excel blank workbook. Please help at your earliest.
Hi:
It can be done without establishing manual connection, but establishing a manual connection is a one minute job. Even if you have multiple users, if the file is shared over the network the link will still work.It is much better than recording the items one-by-one as record set from the data base.
Hi:
Thanks Sir, can you plz tell me record set method?
Hi:
Please find the attached.
Sub accessimport()
Dim db As Database
Dim ws As Workspace
Dim acsql As String
Dim recSet As DAO.Recordset
Set ws = DBEngine.Workspaces(0)
Set db = ws.OpenDatabase _
("your file path here\myDatabase.mdb", _
    False, False, "MS Access;PWD=1234")
Set recSet = db.OpenRecordset("Raw_Data")
Set rng = Sheet2.Range("A1")
lFieldCount = recSet.Fields.Count
For i = 0 To lFieldCount - 1
rng.Offset(0, i).Value = recSet.Fields(i).Name
rng.Offset(1, 0).CopyFromRecordset recSet
recSet.Close
Set ws = Nothing
Set db = Nothing
you will have to put your file path in the highlighted portion before running the macro.
Hi:
Sub accessimport()
Dim db As Database
Dim ws As Workspace
Dim acsql As String
recSet.Close
Set ws = Nothing
Set db = Nothing
Hi, sorry for late reply
thank you so much for the great help, it worked perfectly :)
