Xlsx to XMl Conversion through MAcro Need Help
tanmay2501
HI All,
Can anyone help me out with the Macro that converts that XLSX to XML through VBA on a button click
There would be Nodes in the Data you can seek the help from example below
(Also look in the blank value generation in the xml with only closing tag )
For eg:-
Sheet 1 contains the following data
Column 1 Column 2 Column 3 Column 4
Row 1 Data\School\Name Data\School\Area Data\Affiliation\Type Data\Affiliation\Code
Row 2 ABC Pune CBSE 001
Row 3 XYZ Blank ICSE 002
XML File after conversion
<Data>
<School>
<Name>ABC</Name>
<Area>Pune</Area>
</School>
<Affiliation>
<Type>CBSE</Type>
<Code>001</Code>
</Affiliation>
</Data>
<Data>
<School>
<Name>XYZ</Name>
</Area> (Notice Here Only the end tag is here as there is no data in the sheet for area in the 2nd row)
</School>
<Affiliation>
<Type>ICSE</Type>
<Code>002</Code>
</Affiliation>
</Data>
Thanks for the Help :)
Write the below code user the button click event.
ActiveWorkbook.SaveAs Filename:="FilePath/Filename", FileFormat:=xlXMLSpreadsheet, ReadOnlyRecommended:=False
tanmay2501
by using this code you are saving the whole excel sheet not converting the only sheet 1 data. Dear i just want the desired output nothing else
Sheet 1 data looks like
Output for eg:-
<Data>
<School>
<Name>ABC</Name>
<Area>Pune</Area>
</School>
<Affiliation>
<Type>CBSE</Type>
<Code>001</Code>
</Affiliation>
</Data>
<Data>
<School>
<Name>XYZ</Name>
</School>
<Affiliation>
<Type>ICSE</Type>
<Code>002</Code>
</Affiliation>
</Data>
Tried you above code
But it will give the below output
61115
