XLOOKUP Formula Not Able To Use Correctly
MB028
Hi, I am not able to use the correct XLOOKUP formula in the attached file.
Question: For a Business Unit, there can be multiple Cost Center Levels. Now, I've a list of these Cost Centers combined and need to find out to which Business Unit they belong to?
Thanks for the help!
shrivallabha
You can probably try below formula and see if it helps:
=XLOOKUP(B10,$B$2:$B$5&$C$2:$C$5&$D$2:$D$5,$A$2:$A$5,"",0,1)
MB028
Hi Shrivallabha,
When I'm trying to use this XLOOKUP formula on 2 tabs it's not working for me. I'm sure, I must be doing something wrong in the formula
Can you have a quick look at the attached excel/Tab: PTBS00-ACCT_CC/Cell:H2
shrivallabha
Hi Shrivallabha,
Your formula needs a small correction to match the ranges. See red marked change.
=XLOOKUP(H2,'Global Hierarchy-CEXTCE_SEP-20'!C$8:C$14320&'Global Hierarchy-CEXTCE_SEP-20'!D$8:D$14320&'Global Hierarchy-CEXTCE_SEP-20'!E$8:E$14320&'Global Hierarchy-CEXTCE_SEP-20'!F$8:F$14320&'Global Hierarchy-CEXTCE_SEP-20'!G$8:G$14320,'Global Hierarchy-CEXTCE_SEP-20'!B$8:B$14320,"",0,1)
MB028
Thank you very much Shrivallabha. This works perfectly fine. Have a good day!
Manoj
