Working with pie charts
vletm
Bill Morris
With Your given ... details ... it's a bit challenge to give any ideas.
It's looking as You've done it.
.. but if You could give more details, then You could get some ideas.
Of course, You should know - what would You need to show with it?
Bill Morris
76322It is the example of my pie-chart. I want to make borders for it, then make shadow under the chart and change its angle a little. How can I do it?
Hui
Staff member
Select your chart
then select the Chart design Tab and try the various options
76324
Also select the chart and the press Ctrl+1
Explore the various options
76325
