    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Working code in IE but not in XLMHTTP
Discussion in 'VBA Macros' started by YasserKhalil, Mar 11, 2018.
  1. YasserKhalil
    YasserKhalil Well-Known Member
    1,001
    Hello everyone
    Till now I couldn't get the difference between using IE and XMLHTTP (forgive my ignorance)
    Although I have seen multiple threads I still couldn't get it
    I have the following code that is working in IE
    Code (vb):
    Sub Test_Scrape()
        Dim post        As Object
        Dim elem        As Object
        Dim r          As Long
        r = 2
        With CreateObject("InternetExplorer.Application")
            .Visible = False
            .navigate "https://whub.io/startups?q=&p=0&is_v=1"
            While .Busy = True Or .readyState < 4: DoEvents: Wend
            Application.Wait Now + TimeValue("00:00:05")
            Set post = .document.getElementById("search-startups-results")
            For Each elem In post.getElementsByClassName("ais-hits--item")
                Cells(r, 1).Value = elem.getElementsByTagName("span")(0).innerText
                Cells(r, 2).Value = elem.getElementsByTagName("a")(0).href
                r = r + 1
            Next elem
    But when trying to use XMLHTTP method, I encountered an error at this line
    Code (vb):
    Any help in this topic please?
  2. Marc L
    Marc L Excel Ninja
    4,258
    Hi !
    As on my side this class does not exist within the webpage
    whatever under IE or even Firefox !
    At least check the number of its elements …
    YasserKhalil likes this.
  3. YasserKhalil
    1,001
    That's weird .. but I got results when using IE
  4. Marc L
    Marc L Excel Ninja
    4,258
    As this class does not exist on my side whatever under IE or Firefox,
    I can't go further …​
  5. YasserKhalil
    1,001
    It is already there when inspecting IE
  6. Marc L
    Marc L Excel Ninja
    4,258
    Still nothing whatever IE or Firefox on my side …​
  7. YasserKhalil
    1,001
    That's too weird
    I have tested firefox and inspector and the same result. It's already there
    If it is still not existing for you .. can you edit the code for me that is working for you?
  8. Marc L
    Marc L Excel Ninja
    4,258
    On my side your IE code does nothing as the class does not exist !
    And as you didn't ever explained where is precisely located
    your class element on the webpage, I'm totally blind !
    Maybe it's a country limitation, wait for someone else seeing your class …
  9. Marc L
    Marc L Excel Ninja
    4,258
    Ok now under Firefox but not under IE (no pict with "new"),
    maybe a limitation from my test computer old IE/Windows version
    (common issue under IE) …
    getElementsByClassName works only in early binding way,
    not in late binding way (CreateObject), see shahin recent threads …
  10. YasserKhalil
    1,001
    Thanks a lot ..
    Here's snapshot of an element ..
  11. YasserKhalil
    1,001
    It is working for me either in early or late binding
    Code (vb):
    Sub Test_Scrape()
        Dim ie As New SHDocVw.InternetExplorer
        Dim post        As Object
        Dim elem        As Object
        Dim r          As Long
        r = 2
        With ie
            .Visible = False
                r = r + 1
            Next elem
  12. Marc L
    Marc L Excel Ninja
    4,258
    And without IE, with a request like WinHttp & a DOM element like htmlfile ?
    Chihiro well explained the issue within a thread of shahin …​
  13. YasserKhalil
    1,001
    I don't get that .. I am sorry
  14. Chihiro
    Chihiro Excel Ninja
    5,171
    What Marc is saying that, what's your xmlhttp code? Is all references to external library added to project (early bound) or not? If it isn't, getElementsbyxxx may fail to work. As VBA isn't able to discern what object collection it is (it could have more than 1 type of object in collection).
    At any rate, looks like you are using inspector tool to find the element. When scraping using xmlhttp you need to look at "Source Code" and not inspect element. As some elements can be filled via script and may not be present in the source code (what's returned via request).
    If that's the case, your best option is to pilot IE or use Selenium for other browsers.
  15. Marc L
    Marc L Excel Ninja
    4,258
    I agree but
    I met issues in late binding only with getElementsByClassName
    So the workaround is to not use this statement with htmlfile late binding
    when possible and working by Id, name, tag, …
  16. Chihiro
    Chihiro Excel Ninja
    5,171
    Yes. I prefer using ID whenever possible. But too many sites don't use ID for all elements that I'm interested in :(
    TagName is usually the safest bet if using object to loop, as you've mentioned.
  17. YasserKhalil
    1,001
    Here's my try but failed to get the source
    Code (vb):
    Sub Test()
        Dim myString    As String
        Dim URL        As String
        Dim sPath      As String
        URL = "https://whub.io/startups?q=&p=0&is_v=1"
        sPath = ThisWorkbook.Path & "\Test.html"
        myString = GetHTMLSource(URL)
        OutputText myString, sPath
    Function GetHTMLSource(strURL As String) As String
        Dim XMLHTTP    As Object
        Set XMLHTTP = CreateObject("MSXML2.ServerXMLHTTP")
        With XMLHTTP
            .setTimeouts 2000, 2000, 2000, 2000
            .Open "GET", strURL, False
            .send
            If .Status = 200 Then GetHTMLSource = XMLHTTP.responseText Else GetHTMLSource = ""
    End Function
    Function OutputText(text As String, sPath As String)
        Dim f        As Integer
        f = FreeFile()
        Open sPath For Output As f
        Print #f, text
        Close #f
    End Function
  18. Chihiro
    Chihiro Excel Ninja
    5,171
    Hmm, I can't even open the URL.
    FYI - you should use # in front of "f" in Open sPath for... line.
  19. YasserKhalil
    1,001
    I am totally stuck
    Can you help me with a solution regardless my approach ...?
  20. Marc L
    Marc L Excel Ninja
    4,258
    Can't reach this webpage today whatever the webbrowser !
    As Chihiro yet wrote if data are not in original webpage code
    easier is just to pilot IE …
    Or maybe with a request if you already know
    how to play with dynamic Ajax or Java script
    but if it were the case you didn't use VBA for web scraping …
  21. YasserKhalil
    1,001
  22. YasserKhalil
    1,001
  23. Marc L
    Marc L Excel Ninja
    4,258
    First check if you see data within ResponseText.
    If not, check if you see data within htmlfile (html document)
    once loaded with ResponseText.
    If not, just pilot IE …
  24. YasserKhalil
    1,001
    Can you give me a template code for doing that please?
  25. Marc L
    Marc L Excel Ninja
    4,258
    No template, just check object variable content in VBE Locals window
    as scraping begins with reading, observing, …
    To check text within a global text you can use InStr VBA function.
Share This Page
