Word Macro for inspecting document and removing 3 types of property
ananthram
Hi all,
I am using below macro to remove Document Properties, Personal Information & Custom XML Data. but what i am facing is when i run this macro all the .docx files will be as same extension. But when .doc and .docx will be mixed in the folder then it automatically changes .doc file extension to .rtf and .docx remains the same. Please help me to maintain same extension and let me know if other than removing property what all it does...Thanks in Advance.
Sub Inspection()
Dim strInFold As String, strOutFold As String, strFile As String, strOutFile As String, DocSrc As Document
'Call the GetFolder Function to determine the folder to process
strInFold = GetFolder
If strInFold = "" Then Exit Sub
strFile = Dir(strInFold & "*.docx", vbNormal)
'Check for documents in the folder - exit if none found
If strFile <> "" Then strOutFold = strInFold & "Inspected"
'Test for an existing outpfolder & create one if it doesn't already exist
If Dir(strOutFold, vbDirectory) = "" Then MkDir strOutFold
'Process all documents in the chosen folder
While strFile <> ""
Set DocSrc = Documents.Open(FileName:=strInFold & "" & strFile, AddTorecentFiles:=False, Visible:=False)
With DocSrc
'remove personal information
.RemoveDocumentInformation (wdRDIDocumentProperties)
.RemoveDocumentInformation (wdRDIDocumentServerProperties)
.RemoveDocumentInformation (wdRDIContentType)
'String variable for the output filenames
strOutFile = strOutFold & Split(.Name, ".")(0)
'Save and close the document
.SaveAs FileName:=strOutFile
.Close
strFile = Dir()
Wend
Set Rng = Nothing: Set DocSrc = Nothing
Function GetFolder(Optional Title As String, Optional RootFolder As Variant) As String
GetFolder = CreateObject("Shell.Application").BrowseForFolder(0, Title, 0, RootFolder).Items.Item.Path
End Function
Hi Ananth Ram ,
I am not sure , but try this ( I have not been able to try it out myself , so I cannot say it will work ) :
With DocSrc
sf = .SaveFormat
.SaveAs Filename:=strOutFile, FileFormat:=sf
.Close
Replace the above section in your original code with this slightly modified code.
Sir it actually dint work what i am doubting on is
or
has problem with it.
Hi Ananth Ram ,
I am sorry I cannot help out in this problem , since I am not able to run the macro on my system ; it generates an error : ActiveX component can't create object
Only if this error can be resolved , I can go ahead and try to troubleshoot your macro.
Narayan,
Did you try to run this macro from Excel?
Ananthram,
Does the following work as intended.
Sub Inspection()
strFile = Dir(strInFold & "*.doc*", vbNormal)
If strFile = "" Then Exit Sub
While strFile <> ""
With DocSrc
strOutFile = strOutFold & .Name
.Close
strFile = Dir()
Wend
End Function
Hi Narayan,
I had also come across this and I had tried to find it out:
http://www.mrexcel.com/forum/excel-...429-activex-component-cant-create-object.html
In my opinion, it requires at least one instance of parent application (hidden / visible) running at the time of executing this code. If it is then the code can be run through Excel no problem. While in that thread, "Crystal"[the other user] said that it was not necessary but then she / anyone didn't reply / gave sample which contradicted the observations.
I could be wrong as I have been many times:)
Following code will run through Excel.
Sub RunInspectionThroExcel()
Dim wdApp As Word.Application
Dim boolInstance As Boolean
'Check if instance of Word is running and set the pointer to it
Set wdApp = GetObject(, "Word.Application")
If wdApp Is Nothing Then
Set wdApp = New Word.Application
boolInstance = True
On Error GoTo 0
While strFile <> ""
Set DocSrc = wdApp.Documents.Open(Filename:=strInFold & "" & strFile, AddTorecentFiles:=False, Visible:=False)
With DocSrc
.Close
strFile = Dir()
Wend
If boolInstance Then
wdApp.Quit
Set wdApp = Nothing
End Function
