Why does my code lose formatting while pasting in forum?
rumshar
I was just wondering why the codes pasted by me(despite using code tags) lose formatting? Whereas codes pasted by others appears exactly as in VBE?
With Regards
Rudra
example:
Dim FSO, FileObj, FolderObj As Object
Dim WB As Workbook
Dim MyPath, Msg As String
Dim MyRow As Integer
Dim TDSAmt As Long
Dim TDSDetail, Response As String
Hi, rumshar!
I don't like using VB code tag because of this:
Sub WTFAlignment()
' description
    ' constants
    Const ki1 = 1
    Const ks1 = "1"
    ' declarations
    '  something
    Dim I As Integer
    '  other things
    Dim A As String
    ' start
    A = ""
    ' process
    For I = 0 To ki1
        A = A & ks1
    Next I
    ' end
    MsgBox A
    Beep
I prefer no code tag (in fact "someone" could someday update the dropdown list options at the dialog from "General code", PHP & HTML to something more suitable for these forums usage):
Sub WTFAlignment()
' description
    ' constants
    Const ki1 = 1
    Const ks1 = "1"
    ' declarations
    '  something
    Dim I As Integer
    '  other things
    Dim A As String
    ' start
    A = ""
    ' process
    For I = 0 To ki1
        A = A & ks1
    Next I
    ' end
    MsgBox A
    Beep
The 2nd code reflects the real indenting of my code... With That Fooling Aligment... it's not a choice for me.
Regards!
@SirJB7
Thanks for differentiating these two types. I had not noticed that while 'Coloring' the code one has to compromise with the indent of it..
Just pasting your codes under different tag.(This is for experiment only)
PHP
PHP:
Sub WTFAli2gnment()
' description
    ' constants
    Const ki1 = 1
    Const ks1 = "1"
    ' declarations
    '  something
    Dim I As Integer
    '  other things
    Dim A As String
    ' start
    A = ""
    ' process
    For I = 0 To ki1
        A = A & ks1
    Next I
    ' end
    MsgBox A
    Beep
General
Sub WTFAli2gnment()
' description
    ' constants
    Const ki1 = 1
    Const ks1 = "1"
    ' declarations
    '  something
    Dim I As Integer
    '  other things
    Dim A As String
    ' start
    A = ""
    ' process
    For I = 0 To ki1
        A = A & ks1
    Next I
    ' end
    MsgBox A
    Beep
HTML
HTML:
Sub WTFAli2gnment()
' description
    ' constants
    Const ki1 = 1
    Const ks1 = "1"
    ' declarations
    '  something
    Dim I As Integer
    '  other things
    Dim A As String
    ' start
    A = ""
    ' process
    For I = 0 To ki1
        A = A & ks1
    Next I
    ' end
    MsgBox A
    Beep
