Ankur Kumar
All Here is my vba code just below this message, i having trouble while sending email using vba coding i want to send selective cell range and only active cells copy and paste in the email body, but when i run this it selecting blanks cells also as i have mentioned in the range i.e. A1: C500, instead of active cells, Please help me out.
Sub Suspense_Range_Outlook_Body()
'For Tips see: http://www.rondebruin.nl/win/winmail/Outlook/tips.htm
'Don't forget to copy the function RangetoHTML in the module.
'Working in Excel 2000-2016
Dim rng As Range
Dim OutApp As Object
Dim OutMail As Object
Dim StrBody As String
Dim Signature As String
StrBody = "<H4><B>Dear All,</B></H4>" & _
"Please find below the payment received and request you to provide the invoice number to settle these payments.<br>"
SigString = Environ("appdata") & _
"\Microsoft\Signatures\Ankur.htm"
If Dir(SigString) <> "" Then
Signature = GetBoiler(SigString)
Signature = ""
Set rng = Nothing
'Only the visible cells in the selection
Set rng = Sheets("Sheet2").Range("A1:D500").SpecialCells(xlCellTypeVisible)
'You can also use a fixed range if you want
'Set rng = Sheets("YourSheet").Range("D4:D12").SpecialCells(xlCellTypeVisible)
On Error GoTo 0
If rng Is Nothing Then
MsgBox "The selection is not a range or the sheet is protected" & _
vbNewLine & "please correct and try again.", vbOKOnly
Exit Sub
With Application
.EnableEvents = False
.ScreenUpdating = False
With OutMail
.To = ""
.CC = ""
.BCC = ""
.Subject = "Payment Received" & " " & Format(Date, "dd/MM/yyyy")
.HTMLBody = StrBody & RangetoHTML(rng) & Signature
.Display 'or use .Display
On Error GoTo 0
With Application
.EnableEvents = True
.ScreenUpdating = True
Set OutMail = Nothing
Set OutApp = Nothing
Function GetBoiler(ByVal sFile As String) As String
'Dick Kusleika
Dim fso As Object
Dim ts As Object
Set fso = CreateObject("Scripting.FileSystemObject")
Set ts = fso.GetFile(sFile).OpenAsTextStream(1, -2)
GetBoiler = ts.readall
ts.Close
End Function
Function RangetoHTML(rng As Range)
' Changed by Ron de Bruin 28-Oct-2006
' Working in Office 2000-2016
Dim fso As Object
Dim ts As Object
Dim TempFile As String
Dim TempWB As Workbook
TempFile = Environ$("temp") & "\" & Format(Now, "dd-mm-yy h-mm-ss") & ".htm"
'Copy the range and create a new workbook to past the data in
rng.Copy
Set TempWB = Workbooks.Add(1)
With TempWB.Sheets(1)
.Cells(1).PasteSpecial Paste:=8
.Cells(1).PasteSpecial xlPasteValues, , False, False
.Cells(1).PasteSpecial xlPasteFormats, , False, False
.Cells(1).Select
.DrawingObjects.Visible = True
.DrawingObjects.Delete
On Error GoTo 0
'Publish the sheet to a htm file
With TempWB.PublishObjects.Add( _
SourceType:=xlSourceRange, _
Filename:=TempFile, _
Sheet:=TempWB.Sheets(1).Name, _
Source:=TempWB.Sheets(1).UsedRange.Address, _
HtmlType:=xlHtmlStatic)
.Publish (True)
'Read all data from the htm file into RangetoHTML
Set ts = fso.GetFile(TempFile).OpenAsTextStream(1, -2)
RangetoHTML = ts.readall
ts.Close
RangetoHTML = Replace(RangetoHTML, "align=center xublishsource=", _
"align=left xublishsource=")
'Close TempWB
TempWB.Close savechanges:=False
'Delete the htm file we used in this function
Kill TempFile
Set ts = Nothing
Set fso = Nothing
Set TempWB = Nothing
End Function
Dim rng As Range
Signature = ""
Set rng = Nothing
On Error GoTo 0
Exit Sub
With Application
With OutMail
.To = ""
.CC = ""
.BCC = ""
On Error GoTo 0
With Application
'Dick Kusleika
Dim fso As Object
Dim ts As Object
ts.Close
End Function
Dim fso As Object
Dim ts As Object
rng.Copy
.Cells(1).Select
On Error GoTo 0
.Publish (True)
ts.Close
'Close TempWB
Kill TempFile
Set ts = Nothing
Set fso = Nothing
End Function
