Web scrapping To Excel using VBA
I am trying to scrape particular information from the below website. I have tried by recording macros, but i am not getting output for this particular website only.
Website name : http://xgis.maaamet.ee/ky/FindKYByT.asp
I have two column in my Excel sheet. Column A have some parcel numbers and Column B is Area.
If i entered parcel number like 41201:004:0068, i need to get 3900 m² in Column B
Is that possible.
If you know the math you are better to replicate the web site logic in Excel
Do you know what te logic is ? or even a description in English would help us help you
Do Google Earth or Bling offer a similar output/service ?
Reading the documentation at the web site I think if you contact the author (Section 5) of the manual he may be able to assist with an Excel or direct web link
"5. Support
If you have any problems or questions regarding the use of Quick Query, please send an e-mail with the description of problem or question to kaardirakendus@maaamet.ee or call..."
Hi rajesh !
In the documentation is written how to directly load the parcel page, just read it !
To grab data, read the VBA inner help of QueryTable object for example
or any other ways in this forum or all over the web !
Thanks Hui and Marc,
I have tried by recording macros using the manual.
With ActiveSheet.QueryTables.Add(Connection:= _
        "URL;http://xgis.maaamet.ee/ky/vorm", Destination:=Range("$A$1"))
        .Name = "vorm"
        .FieldNames = True
        .RowNumbers = False
        .FillAdjacentFormulas = False
        .PreserveFormatting = True
        .RefreshOnFileOpen = False
        .BackgroundQuery = True
        .RefreshStyle = xlInsertDeleteCells
        .SavePassword = False
        .SaveData = True
        .AdjustColumnWidth = True
        .RefreshPeriod = 0
        .WebSelectionType = xlSpecifiedTables
        .WebFormatting = xlWebFormattingNone
        .WebTables = "2"
        .WebPreFormattedTextToColumns = True
        .WebConsecutiveDelimitersAsOne = True
        .WebSingleBlockTextImport = False
        .WebDisableDateRecognition = False
        .WebDisableRedirections = False
        .Refresh BackgroundQuery:=False
    Range("B1").Select
When i was recording macro, i entered URL as "http://xgis.maaamet.ee/ky/FindKYByT.asp?txtCU=72704:004:0430", but in macro its showing as "http://xgis.maaamet.ee/ky/vorm"
i need to change txtCU everytime, so by using this code, i can't change it.
Any idea?
Means to pilot Internet Explorer …
Other web search : microsoft XMLHTTP …
But for a noob the easy way is to follow Hui's post #3 !
Hi
I have written some code using XML HTTP, still i am getting error as "Table not found". Here is my code.
Sub AdditionalInfo()
    Dim oDom As Object: Set oDom = CreateObject("htmlFile")
    Dim x As Long, y As Long
    Dim oRow As Object, oCell As Object
    Dim data, aTable As Object
    y = 1: x = 1
    With CreateObject("msxml2.xmlhttp")
        .Open "GET", "http://xgis.maaamet.ee/ky/FindKYByT.asp?txtCU=72704:004:0430", False
        .send
        oDom.body.innerHTML = .responseText
    For Each aTable In oDom.getElementsByTagName("table")
        If Trim(LCase(aTable.className)) = "tblPager" Then
            With aTable
                ReDim data(1 To .Rows.Length, 1 To .Rows(1).Cells.Length)
                For Each oRow In .Rows
                    For Each oCell In oRow.Cells
                        data(x, y) = oCell.innerText
                        y = y + 1
                    Next oCell
                    y = 1
                    x = x + 1
                Next oRow
            Exit For
    Next aTable
    With Sheets(2).Cells(1, 1)
        .CurrentRegion.ClearContents
        If IsArray(data) Then
            .Resize(UBound(data), UBound(data, 2)).Value = data
        Else: MsgBox "Table not found"
Code looks good but web page seems to be written in CSS style,
more difficult to grab data than normal pages …​
In fact if you kwow how to use your web browser, you can see the request called like this :
http://xgis.maaamet.ee/ky/vorm?xVRM.AASave=Otsi&F3X7tNFk=72704:004:0430&FVc3zIa6=&FMu0oiRJ=&FFUHGuoP=
But bold parts change at each request, like a time protection I guess …
Using IE is no more a pleasure : Ajax type webpage with cascade of dynamic iFrames, lost in dedalus !
Maybe you could take a glance at a webdriver wrapper like Selenium v2, no guarantee but an easy way …
