Did you consult the formula help function of Excel? That's always a good place to start.
VLOOKUP requires the lookup value to be in the left most column of your search area. You are looking up pan, but pan is in column B, so your search area may not start in A. It should be the range B2:F8.
MATCH will return a position in a range (row/column number). To return a value it can be combined and wrapped within an INDEX function.
Now I'm presuming you used google translate or so, making it hard for me to exactly understand what your were after. But have a look at the attached file. Example given with both vlookup and index/match. See if those are already helping you.
