Vlookup in Subtotal = Problems...... Address in Subtotal = Problems :(
mgris
I was trying to do a subtotal that contained a vlookup formula.
It didn't work...
I realized that subtotal needs a cell reference to function, and not a value...
I've tried few things with the Address function, but if I'm right it returns the address as a string content and does not "refer" to the cell itself...
Do you have any idea on how to correct my mistakes?
Thx,
M.
Hi xld,
Hmmm... A data sample would require lengthy explanations.
So just to try to make it clearer, here is what I'm trying to do in one single formula:
- Search a certain value with vlookup
- Once the value is found, get the address of the cell that contains it
- In order to use it in a subtotal...
Hope it will help you help me :)
Cheers,
M.
VLOOKUP is not needed (it's somewhat overkill) since the real question is what row is the data in, not what the value is. Perhaps something like:
=SUBTOTAL(Function#,B1:INDIRECT("B"&MATCH(LookupValue,A:A,0)))
Since you didn't post your formula, I had to make several guesses.
I'm assuming your looking at a range of stuff to subtotal, not just 1 cell (else, why "total" it?)
I assumed the your vlookup was originally looking for some value in col A and returning the value from col B. You will need to change those reference if this is not correct.
