Hi All, Can any one help in this vba code. I need to pull <div class codes which are highlighted in yellow color in the Html code to excel file. The out put that is need is listed below.
The out put that i need should be like below table.
Thanks for you help,
Rsha
Sub GetDat()
Dim IE As New InternetExplorer, html As HTMLDocument
Dim elem As Object, data As String
With IE
.Visible = True
.navigate "https://MYURL/sc/wo/WO/index?id=76888564"
Do While .readyState <> READYSTATE_COMPLETE: Loop
Set html = .document
data = ""
For Each elem In html.getElementsByClassName("simple-list")(0).getElementsByTagName("li")
data = data & " " & elem.innerText
Next elem
Range("A1").Value = data
IE.Quit
Date | Feedback |
3 Dec 13 2016 23:30 CST | At this time the work order has been updated to a billable status. Your company can process an invoice against the work order. For any questions regarding invoicing, refer to the Invoice instructions on the Help Link in |
2 Dec 11 2016 02:15q | Status changed by auto-update procedure. |
1 Dec 01 2016 01:51 CST | Auto Dispatch summary sent to divisionsinc.com on Dec 01, 2016 02:50 EST |
Rsha
