VBA to iterate through Slicer Items (Power Pivot)
Christof
I have developed a dashboard that links my entire data model using Power Pivot and gives a nice range of tables as an output.
My question is, is it possible to create a macro button that will select each item in the slicer, and then print it.
I have done this in the past using a dropdown menu, but was wondering if it's possible to do with a slicer box?
Any help would be greatfully appreciated.
Chris
Marc L
Hi, restart from here :​
GraH - Guido
After reading the previous, you can continue here: Using SELECTEDVALUES To Capture Power BI Slicer Selections. It contains a link that explains how to list even multiple selections from a slicer. Then making the macro your after would be easy for you I assume since you did it before via drop down selections.
