VBA to filter data based on column and copy to the body of the mail
Status
Not open for further replies.
Hello Experts,
I have set of columns as below:
73613
I want data to be filtered with column D (Deal Owner) and copy the filtered data (only column A, B & C) to the body of the email as a table and send mail to email address in column 'F'. In simple need to filter data with unique deal owner and send mail as a table to the respective owner.
Appreciate your help. Thank you in advance.
  • Deal Info.xlsx
Like this?
Perfect !! Firstly, Thank you for looking into it !!
1. However, instead of a drop down list, can it be possible to trigger all emails to the unique owners in one go.
2. In the email the data is converting into text, which is causing the borders. (I mean borders are not complete). If possible can we paste a table ?
Thank you for the help in advance !!
just wanted to check if you got a chance to look in the above scenario.
Hi all,
here's my attempt:
Sub mailK()
    'https://chandoo.org/forum/threads/vba-to-filter-data-based-on-column-and-copy-to-the-body-of-the-mail.45912/
    Dim Wks    As Worksheet
    Dim OutMail As Object
    Dim OutApp As Object
    Dim myRng  As Range
    Dim list   As Object
    Dim item   As Variant
    Dim LastRow As Long
    Dim uniquesArray()
    Dim Dest   As String
    Dim strbody
    Set list = CreateObject("System.Collections.ArrayList")
    Set Wks = ThisWorkbook.Sheets("Deal Info")
    With Application
        .EnableEvents = False
        .ScreenUpdating = False
    With Wks
        For Each item In .Range("E2", .Range("E" & .Rows.Count).End(xlUp))
            If Not list.Contains(item.Value) Then list.Add item.Value
    For Each item In list
        Wks.Range("A1:F" & Range("A" & Rows.Count).End(xlUp).Row).AutoFilter Field:=5, Criteria1:=item
        LastRow = Cells(Rows.Count, "A").End(xlUp).Row
        Set myRng = Wks.Range("A1:C" & LastRow).SpecialCells(xlCellTypeVisible)
        Dest = Cells(LastRow, "F").Value
        strbody = "Dear ," & "<br>" & _
                  "See the list of deals" & "<br/><br>"
        With OutMail
            .To = Dest
            .CC = ""
            .BCC = ""
            .Subject = "Deals"
            .HTMLBody = strbody & RangetoHTML(myRng)
            .Display
            '.Send
        On Error GoTo 0
    Wks.ShowAllData
    On Error GoTo 0
    With Application
        .EnableEvents = True
        .ScreenUpdating = True
Function RangetoHTML(myRng As Range)
    Dim TempFile As String
    Dim TempWB As Workbook
    Dim fso    As Object
    Dim ts     As Object
    Dim i      As Integer
    TempFile = Environ$("temp") & "\" & Format(Now, "dd-mm-yy h-mm-ss") & ".htm"
    myRng.Copy
    Set TempWB = Workbooks.Add(1)
    With TempWB.Sheets(1)
        .Cells(1).PasteSpecial Paste:=8
        .Cells(1).PasteSpecial xlPasteAllUsingSourceTheme, , False, False
        .Cells(1).Select
        .DrawingObjects.Visible = True
        .DrawingObjects.Delete
        On Error GoTo 0
        For i = 7 To 12
            With .UsedRange.Borders(i)
                .LineStyle = xlContinuous
                .ColorIndex = xlAutomatic
                .TintAndShade = 0
                .Weight = xlMedium
    With TempWB.PublishObjects.Add( _
         SourceType:=xlSourceRange, _
         Filename:=TempFile, _
         Sheet:=TempWB.Sheets(1).Name, _
         Source:=TempWB.Sheets(1).UsedRange.Address, _
         HtmlType:=xlHtmlStatic)
        .Publish (True)
    Set fso = CreateObject("Scripting.FileSystemObject")
    Set ts = fso.GetFile(TempFile).OpenAsTextStream(1, -2)
    RangetoHTML = ts.readall
    ts.Close
    RangetoHTML = Replace(RangetoHTML, "align=center x:publishsource=", _
                  "align=left x:publishsource=")
    TempWB.Close savechanges:=False
    Kill TempFile
    Set ts = Nothing
    Set fso = Nothing
    Set TempWB = Nothing
End Function
  • Deal Info Keetoowah.xlsm
Hi Keetoowah,
I am getting error on below step, any idea what could be the reason.
So if list is an Object variable then this ActiveX is missing on your Windows (or damaged), to see with your IT …​
Hi all,
here's my attempt:
Sub mailK()
    Dim myRng  As Range
    Dim list   As Object
    Dim item   As Variant
    Dim LastRow As Long
    Dim uniquesArray()
    Dim Dest   As String
    Dim strbody
    With Application
    With Wks
        With OutMail
            .To = Dest
            .CC = ""
            .BCC = ""
            .Subject = "Deals"
            .Display
            '.Send
        On Error GoTo 0
    Wks.ShowAllData
    On Error GoTo 0
    With Application
    Dim fso    As Object
    Dim ts     As Object
    Dim i      As Integer
    myRng.Copy
        .Cells(1).Select
        On Error GoTo 0
        For i = 7 To 12
                .TintAndShade = 0
                .Weight = xlMedium
        .Publish (True)
    ts.Close
    Kill TempFile
    Set ts = Nothing
    Set fso = Nothing
End Function
Hi, extremely useful.
Would it be possible to attach the filtered data as an excel document instead of a table in the email body?
As a reminder the classic VBA Collection can be used rather than an external ActiveX like ArrayList, Dictionary, …​
Hello everybody,
as suggested by @Marc L, I publish an adapted version that uses a Collection instead of a Dictionary, it should solve the problems of MAC users
Sub mailKclct()
    Dim OutMail     As Object, OutApp As Object
    Dim cel         As Range, myRng As Range
    Dim Itm         As Variant
    Dim LastRow     As Long
    Dim Dest        As String, strbody As String
    Dim collOwner   As New Collection
    For Each cel In Wks.Range("E2:E" & Range("E" & Rows.Count).End(xlUp).Row)
        collOwner.Add cel.Value, CStr(cel.Value)
    On Error GoTo 0
    With Application
    For Each Itm In collOwner
        Wks.Range("A1:F" & Range("A" & Rows.Count).End(xlUp).Row).AutoFilter Field:=5, Criteria1:=Itm
        With OutMail
            .To = Dest
            .CC = ""
            .BCC = ""
            .Subject = "Deals"
            .Display
            '.Send
        On Error GoTo 0
    Wks.ShowAllData
    On Error GoTo 0
    With Application
    Dim fso         As Object
    Dim ts          As Object
    Dim i           As Integer
    myRng.Copy
        .Cells(1).Select
        On Error GoTo 0
        For i = 7 To 12
                .TintAndShade = 0
                .Weight = xlMedium
        .Publish (True)
    ts.Close
    Kill TempFile
    Set ts = Nothing
    Set fso = Nothing
End Function
Hello Keetowah ! You should replace FSO too as on MAC any Windows ActiveX can't be used …​
Hello everyone again,
thanks to @Marc L for reporting my inattention, here is an updated version of the code that uses the ExcelSirJi function ConvertRangeToHTMLTable instead of the well known Ron de Bruin function RangetoHTML
Sub mailKclct2()
    Dim Itm         As Variant
    Dim LastRow     As Long
    On Error GoTo 0
    With Application
        With OutMail
            .To = Dest
            .CC = ""
            .BCC = ""
            .Subject = "Deals"
            .HTMLBody = strbody & ConvertRangeToHTMLTable(myRng)
            .Display
            '.Send
        On Error GoTo 0
    Wks.ShowAllData
    On Error GoTo 0
    With Application
'Following function converts Excel range to HTML table
Public Function ConvertRangeToHTMLTable(rInput As Range) As String
'https://www.excelsirji.com/vba-code-to-convert-excel-range-into-html-table/
    'Declare variables
    Dim rRow As Range
    Dim rCell As Range
    Dim strReturn As String
    'Define table format and font
    strReturn = "<Table border='1' cellspacing='0' cellpadding='7' style='border-collapse:collapse;border:none'>  "
    'Loop through each row in the range
    For Each rRow In rInput.Rows
        'Start new html row
        strReturn = strReturn & " <tr align='Center'; style='height:10.00pt'> "
        For Each rCell In rRow.Cells
            'If it is row 1 then it is header row that need to be bold
            If rCell.Row = 1 Then
                strReturn = strReturn & "<td valign='Center' style='border:solid windowtext 1.0pt; padding:0cm 5.4pt 0cm 5.4pt;height:1.05pt'><b>" & rCell.Text & "</b></td>"
                strReturn = strReturn & "<td valign='Center' style='border:solid windowtext 1.0pt; padding:0cm 5.4pt 0cm 5.4pt;height:1.05pt'>" & rCell.Text & "</td>"
        Next rCell
        'End a row
        strReturn = strReturn & "</tr>"
    Next rRow
    'Close the font tag
    strReturn = strReturn & "</font></table>"
    'Return html format
    ConvertRangeToHTMLTable = strReturn
End Function
Hi all,
here's my attempt:
Sub mailK()
    Dim myRng  As Range
    Dim list   As Object
    Dim item   As Variant
    Dim LastRow As Long
    Dim uniquesArray()
    Dim Dest   As String
    Dim strbody
    With Application
    With Wks
        With OutMail
            .To = Dest
            .CC = ""
            .BCC = ""
            .Subject = "Deals"
            .Display
            '.Send
        On Error GoTo 0
    Wks.ShowAllData
    On Error GoTo 0
    With Application
    Dim fso    As Object
    Dim ts     As Object
    Dim i      As Integer
    myRng.Copy
        .Cells(1).Select
        On Error GoTo 0
        For i = 7 To 12
                .TintAndShade = 0
                .Weight = xlMedium
        .Publish (True)
    ts.Close
    Kill TempFile
    Set ts = Nothing
    Set fso = Nothing
End Function
Hi all,
here's my attempt:
Sub mailK()
    Dim myRng  As Range
    Dim list   As Object
    Dim item   As Variant
    Dim LastRow As Long
    Dim uniquesArray()
    Dim Dest   As String
    Dim strbody
    With Application
    With Wks
        With OutMail
            .To = Dest
            .CC = ""
            .BCC = ""
            .Subject = "Deals"
            .Display
            '.Send
        On Error GoTo 0
    Wks.ShowAllData
    On Error GoTo 0
    With Application
    Dim fso    As Object
    Dim ts     As Object
    Dim i      As Integer
    myRng.Copy
        .Cells(1).Select
        On Error GoTo 0
        For i = 7 To 12
                .TintAndShade = 0
                .Weight = xlMedium
        .Publish (True)
    ts.Close
    Kill TempFile
    Set ts = Nothing
    Set fso = Nothing
End Function
@Keetoowah Thanks for such a wonderful and understandable code. I was trying to attach the filtered Table in excel in mail attachment also along with mail body table. Can you please help us with editing in the above code.
Status
